Nightster stalling problem
Old Mar 18, 2011 | 05:58 PM
cagedodger's Avatar
cagedodger
I installed all of these mods myself and I have messed with the plugs to clean them before. I guess this weekend Ill tear the freakin bike apart and get new gaskets and overlook everything AGAIN. If the bike is still missing after that then I guess I will try the $200 dynotune.
Old Mar 18, 2011 | 06:02 PM
Osco's Avatar
Osco
Account Deactivated
I would not tear it apart,,,maybe just the Intake side,,,
Pop yer stock airfilter in and start It the next am,,,,,
Its prolly sumthin soooo simple you'll freak when ya find it.
Go back to the website and see If they have fuel setups that are a bit richer.
Do they list the parameters,,,the AFR In closed and open loop ???
Old Mar 18, 2011 | 06:40 PM
cagedodger's Avatar
cagedodger
If there was a leak would the dynotune for sure find it?. If so I will stop being cheap and definitely get that done. My worry is that it could possibly be a leak.
Old Mar 19, 2011 | 10:28 AM
stevelonewolf's Avatar
stevelonewolf
If you would like to check to see if your intake seals are leaking, @ idle(even if you have to hold the throttle) just take a can of contact/brake clean and put the little red straw on the can trigger and shoot a couple of shots directly on the front then rear intakes and if the idle changes rmp levels either way, your intakes are toast.....
Old Mar 19, 2011 | 11:06 PM
cagedodger's Avatar
cagedodger
I like to do my own work but I don't want to damage my engine messing with fuel tables.
That saying Ive read on here before "this isn't rocket science its a Harley" doesn't work anymore. These EFI bikes are pretty tricky. I'm just going to save up some money and take it to the stealership.
Old Mar 19, 2011 | 11:07 PM
cagedodger's Avatar
cagedodger
Thanks for the helpful responses.
Romad12
Jul 19, 2016 10:33 PM
Tricknick
Jun 26, 2014 01:02 PM
jtNIGHTSTER1
Oct 1, 2013 06:16 AM
09HDNIGHTSTER
May 31, 2013 01:14 AM
little_mac
May 24, 2010 02:48 AM
