Ignition Problems
Old Apr 4, 2011 | 08:06 PM
Black Raven's Avatar
Black Raven
Stage II
Default Ignition Problems
Okay so here's the problem. The last several times I've started my 2010 Iron 883 I've been having this particular issue. The bike starts up fine, but after about a minutes it sputters and dies. Then when I re-start it will not stay on unless I play with the throttle. I have to hold the throttle back for about a minute or two all while the exhaust sputters, pops, and the bike struggles to stay on. Then the bike will settle in and all is fine. The bike will run fine and even after I shut it off, it will start right back up (unless I turn it off for a period of half an hour) then I have to go through the whole process again. Any ideas here, Please. Note that the bike is all stock has no modifications.
Old Apr 4, 2011 | 08:18 PM
Aaron48's Avatar
Aaron48
Bad Gas Maybe....If not get that sucker to the dealer given its a 2010 still under warranty right. Make THEM fix it.
Old Apr 5, 2011 | 06:56 AM
Black Raven
Stage II
I have to check about the warranty. I bought from a non Harley Dealer and they gave a 90 Day warranty covered by the them. They never mentioned the Harley Warranty, and now that I research it it appears that if you sell your bike while under warranty you also have to transfer the warranty. Is this true?
LowRider289
Aug 31, 2017 01:14 PM
BigD629
Jun 11, 2012 11:00 PM
SodFather
Feb 16, 2011 02:17 PM
rdoucet
Sep 21, 2009 06:17 PM
honestbob
Nov 16, 2008 07:57 PM
