Do I need to add any bushings to the strut before I install it, or just place the bolt thru the mounting hole on the strut?
Do you actually mean "bushing" or "spacer"?
Spacers you might need because many struts aren't as wide as the stock shocks are.
Bushings you would only need if the hole in the strut is larger than the bolt from the shocks.
But with no idea of what struts you have, and nothing in your post reveals that, there is no way that any of us could make an intelligent determination. The previous poster must be just relying on what he needed when he did his, unless he knows you and knows what struts you have. But the rest of us have no clue what struts you have and cannot make an intelligent decision.
Just installed some struts on my 48 yesterday afternoon, no bushings here either. The only issue i encountered was the bike sat too low to get off the jack. Had to pick it up and carry it off the jack
