Clutchless shifting
I happen to know very well how gearbox - any gearbox - works. The very idea of gearbox is to adapt the working range of engine to the actual speed of vehicle. Regardless how many steps a gearbox has they still are steps. Which means RPM of the engine is gradually changed while switching thru gears which it is not the case with variator transmission for instance. Thus, when changing the gear ratio instantly the RPM of engine has to change in same instant - which contradicts all what mankind knows about physics.
Furthermore, whoever said racers do it all the time ... I'd really ask what kind of racing we are talking about?
In closed circuit racing where one accelerates out of turn while still leaning a clutchless gear change will result in a highsider with certainty. MotoGP, Superbike, etc. all use clutch, although sometimes it is automatic when switching up.
well said , kinda like all engineer's.."It works in my mind , and on paper"
"any gearbox" ??? there are more than a few ..dogshift, syncromesh,open ,keywaydrive, some move actual gears, some dont
"A helicopter cannot fly" ," neither can a hummingbird".(engineering 101)
however , if you have the slightest mechanical feel, and understand the physics of a constant mesh trannny, any can be shifted clutchless without harm .
It does take the understanding of the machine ..
yes you can clutchless shift while leaning without highside .
But it requires a ability to understand the machine ..just not the theory...books are fine , theory is fine ..
"what part of "blipping the throttle" confuses you ?.
last I checked ,that changes, maybe matches the rpm for seamless shifting....go figgure
I am out of this discussion ,,,no winners...every one have a good one.
It does take the understanding of the planet system ..
yes you can sail to the edge of Earth without falling over the edge .
But it requires a ability to understand the planet ..just not the theory...books are fine , theory is fine ..
In my experience the technique is less suitable for Harleys, largely because they have a fairly wide-ratio transmission. The change from first to second is not something I would normally try, indeed I normally only skip the clutch changing into top gear (my Harleys are all five-speed).
Despite all the debate there is absolutely no reason for not riding with clutchless changes, they simply require a little skill. But then that can be said of using the clutch!
