Ignition interuption
Old May 7, 2011 | 01:24 PM
axle357's Avatar
axle357
Stage II
Default Ignition interuption
Hello,
I have a 91 Sportster with a remanned 883, now a 1200. During the first 5 minutes after a cold start the engine just quits for 10 to 15 seconds, if i have sufficient speed up it will backfire a few times and then restart. Sometimes I roll to a complete stop and then after cranking it a while it will restart. Then it will usually run fine until the next cold start up. Sometimes it does it twice. It seems to me it must be an ignition problem, hence the backfiring.
Anybody know what's up with this?
Thanks
Old May 7, 2011 | 08:16 PM
jruggs73's Avatar
jruggs73
Try running the first 10-15 minutes with the choke out just a little....mine did that and that helped a lot. I can see about 1/4" of shaft on the choke. I usually go 10 minutes then push it in and it's good for the day.
BarnSeven
May 23, 2018 03:16 PM
axle357
May 7, 2011 01:32 PM
87XLH1100
Aug 31, 2010 04:01 PM
Badass67stang
Nov 25, 2009 10:05 AM
nathanbedfordforrest
Ironhead
Aug 5, 2007 02:38 PM
