Need help identifying noise...
Old May 20, 2011 | 12:17 PM
Scionic Wraith's Avatar
Scionic Wraith
Default Need help identifying noise...
Starting to hear a noise that sounds like pulsing metal on metal squeaking. It is only happening when riding in the rain. I notice the sound doesn't happen when I'm accelerating or maintaining acceleration. When I let oof the accelerator it starts. If I pull in the clutch, it quits. Engage the clutch and it starts up again. Like I said, it's only happening when it rains. Any ideas what might be doing this?
Scionic
Old May 20, 2011 | 08:17 PM
WRAITH's Avatar
WRAITH
Drive belt.
Old May 21, 2011 | 03:32 AM
Osco's Avatar
Osco
Account Deactivated
A too tight drive belt Is often a problem,,It can bind the suspension on a bike with
enough rear suspension travel for the swingarm to pass through a "Level" plane.
Also a belt can ride hard against the side of the rear pully due to a slightly
misaligned rear tire. This can cause a problem like yours.
First Inspect the belt carefully, then check rear wheel alignment
then check tension.
With your thumb and pointer finger only Grab the belt In the middle
of both sprockets..
You should be able to twist the belt to the vertical,,no farther.
Belt tension guages,,Pffft Time to go Old school.
Old May 23, 2011 | 10:28 AM
Scionic Wraith
Man, busy weekend, didn't login to computer all weekend, just got these messages.
Ok, I ran out to the parking garage this morning, the belt shows no signs that it needs to be changed. No cracks, pieces missing, or damaged "teeth?".
I did the twist test, and without using two hands and my body weight, I could not get it straight up and down. I made it 2/3 of the way. So, I can relieve a bit of tension.
As for alignment, using a metal rule, where would I measure? From the axle, what reference point can I measure to check, as accurately as I can, both sides for alignment?
Thanks for the responses, slowly but surely I'm learning more about my bike. I love working on it myself.
- Scionic
Old May 23, 2011 | 11:07 AM
cHarley's Avatar
cHarley
Correctly adjusted for tension, the belt should twist 45*. (That's 1/2 way between flat & straight up )
The English guy
Oct 14, 2015 02:18 AM
xhere
2014-2024 Touring Models
Jun 7, 2014 08:58 AM
ricktara
Aug 2, 2009 02:12 PM
Bigfoots03HD
Jan 20, 2009 05:12 PM
smithr
Aug 20, 2007 02:26 PM
