87xlh 1200 conversion.
only running on one cylinder. has dyna ignition .
changed plugs and wires. fire is not very hot on the rear cylinder wchich i think is the problem because it will run eiter cylinder off of the left side of the coil pack when i switch the wires.
is this the coil or is it something to do with the blue and white wires coming form the ignition or could it be something else?
thanks alot guys, I am just trying to ride with my family before i go back to ohio for work. thanks again
