Changing Brake Pads
Old Jun 8, 2011 | 12:47 PM
cameraboy's Avatar
cameraboy
Default Changing Brake Pads
I"m about to change the brake pads on my 09 iron 883 this weekend.
I have the service manual and the instructions that come with the new pads, but any advice or tips any of you could offer would be greatly appreciated.
Thank you
Old Jun 8, 2011 | 01:46 PM
jbyun's Avatar
jbyun
I ran into this when I wanted some info:
http://www.youtube.com/watch?v=L2roHLe3NEc
Looks like this guy goes all out and removes everything and cleans it but the service manual actually recommends NOT doing that.
In any case, vidoes are helpful so definitely check out Youtube or other video sites if that helps.
Old Jun 8, 2011 | 02:36 PM
WVHogRider's Avatar
WVHogRider
My only tip be to make sure the beer is at 36* or so, and the stripper you order to dance around while you change'em out is HOT, as it's an easy job.
Old Jun 8, 2011 | 03:03 PM
cameraboy's Avatar
cameraboy
SWEET.
Thanks guys
Old Jun 8, 2011 | 05:12 PM
xFreebirdx's Avatar
xFreebirdx
Old Jun 8, 2011 | 06:08 PM
Gpsjr10's Avatar
Gpsjr10
I went to pull my pads off today to inspect them and found I needed a 5mm allen wrench to remove the pin from the caliper that goes through the holes in the pads. Figures it was missing from my only metric set. Also the 2 mounting bolts to the fork is a 12 point 10mm socket
Old Jun 8, 2011 | 09:10 PM
MisterPX's Avatar
MisterPX
Antiseize on teh sliders, if no piston pusher, channel locks work.
Not sure if SM talks about cleaning/scuffing teh rotors.
bobalew
Feb 9, 2014 10:49 PM
LDB187
Mar 16, 2012 08:27 PM
Gordon65
Mar 25, 2010 09:30 PM
primeaus883
Mar 15, 2008 10:48 AM
jd_underdog
Apr 22, 2006 12:07 AM
