HELP: Leak Between the Rocker Cover and Head Cylinder
Old Jun 9, 2011 | 09:52 AM
Voony's Avatar
Voony
Originally Posted by 1200Cdriver
Voon, my 2007 1200C leaks on the rear cylinder on the other side of the engine from yours. The oil level does not go down, the leak is small but the mess is big. It started at about 12,000 miles, I'm now at 14,900, the front cylinder's gaskets do not leak. I have the Cometic site book marked for when I make my move.
We have the same issue! I got oil splatters on the left side of the cylinder as well but the oil level is still the same. Since I ride everyday, the mess is big for me too.
I'm going to make my move soon too. Tired of cleaning the rear cylinder
Old Jun 9, 2011 | 10:57 AM
bmxatv's Avatar
bmxatv
i use the cometic gaskets exclusively. guy at my indy used them we he tore my motor apart and swears by them.
Old Jun 9, 2011 | 11:41 AM
WVHogRider's Avatar
WVHogRider
1200C & 9Vapors.......You do know there's bolts inside holding down each rocker plate,and not just those four allen head bolts on top, right?
And I used James Gaskets last time I went in my engine.
Old Jun 9, 2011 | 01:03 PM
Wjtater's Avatar
Wjtater
I had the same problem. Get the manual, an inch pound torque wrench, new gaskets, and some long allen sockets with the ***** on the ends. It's not that hard, I did it and I have some mechanical skill.
Attached Thumbnails HELP: Leak Between the Rocker Cover and Head Cylinder-ok-106.jpg   HELP: Leak Between the Rocker Cover and Head Cylinder-ok-107.jpg
Old Jun 9, 2011 | 01:07 PM
Wjtater's Avatar
Wjtater
Another couple pics
Attached Thumbnails HELP: Leak Between the Rocker Cover and Head Cylinder-ok-108.jpg   HELP: Leak Between the Rocker Cover and Head Cylinder-ok-082.jpg   HELP: Leak Between the Rocker Cover and Head Cylinder-ok-106.jpg
Old Jun 9, 2011 | 01:12 PM
1200Cdriver's Avatar
1200Cdriver
Thanks y'all, I have read several threads on this issue so I am aware of the weird construction of the head assembly. I have lots of tools all I need is a little courage. I guess I should do it now I'm due for an oil change in about 200 miles.
Old Jun 9, 2011 | 02:00 PM
Kman Harley's Avatar
Kman Harley
When I first got my '99 restoration project the tops in those areas leaked bad, cranking the engine and when the engine was running you could feel and hear the air coming out and of course oil too. Pulled it down and whichever retard that worked on the bike to replace the gaskets placed them in badly so they weren't sealing in places, crumpled and even torn in one spot. I didn't have any new seals and there's no dealer here for me to get them from so I took a gamble and used some Permatex gasket maker which I've used on cars for valve covers and such (might have been the high temp one, can't remember) and it worked like a charm, no leaks what-so-ever. And to be honest I'm considering using it onright side engine cover where the cams are cause I redid that one with a proper seal and I have a friggin leak and it was almost right away after installing it - no tears or anything. To be honest if the gasket maker stuff can be used for oil pumps/water pumps and such on cars I don't see why it can't work for there too.
Old Jun 9, 2011 | 02:35 PM
Voony's Avatar
Voony
WJtater: I will most likely do it myself. I called two dealers and one indy in my area and they all quoted me two hours of work for just one head, all around $176-190 for the labor + $40 in parts. That sounds awfully expensive to replace a gasket.
They told me that there are 3 types of gaskets in the rocker box and that I'd have to replace all of them.
Newbie question: what is an one inch pound torque wrench? :-)
Old Jun 9, 2011 | 09:39 PM
ride2tires's Avatar
ride2tires
I use this conversion program all the time. Proves very handy in the barn on the laptop....
click here
Old Jun 9, 2011 | 10:12 PM
Voony's Avatar
Voony
click here
If this is regarding my question about the wrench, I simply don't know if it's a specific type of wrench that I need?
