Relocating the front lights
Old Nov 2, 2006 | 11:21 PM
utz's Avatar
utz
Default Relocating the front lights
Thinking of buying the relocator kit.Is it a tough job.How long does it take. Thanks
Old Nov 3, 2006 | 12:17 AM
Dr.Cool's Avatar
Dr.Cool
Default RE: Relocating the front lights
No, its not a tough job, and it takes about a half hour if you have the wiring tools. I got the harley parts to do it. The thing to remember is you need to cut all the wires about 1.25 inches from eachother so the shrink tube fits over the connecters. If you dont and you cut the wires at the same place, then you have a big ball when you connect everything back up.
Old Nov 3, 2006 | 10:43 AM
brendajmull's Avatar
brendajmull
My hubby did mine for me and it did not take long at all, I love the way the front end looks now..
Old Nov 3, 2006 | 12:13 PM
pjweber's Avatar
pjweber
I did mine, looks great. You DO NOT have to cut the wires, I hate cutting wires. I removed the riser and I had to loosen up the headlight assembly and I 're-routed' the wires to get a little more slack. It will take a little longer but you won't have splices in your wiring then.
Good Luck!
Old Nov 4, 2006 | 12:06 PM
cmas06's Avatar
cmas06
Just my .02, i did the relocate too with the hd parts and if ya look close thier made in china, and dont hug the fork brace to well and mine ended up cracking. Im replacing them with the ones that actually clamp the fork tube .I belive there from Kuryakin or custom chrome
Old Nov 4, 2006 | 01:18 PM
OldFenderGuy's Avatar
OldFenderGuy
ORIGINAL: cmas06
I'm using the Custom Chrome on mine.
I have the 41mm tubes, but they also have them for the standard 39mm tubes.
Only cost around $20, and the fit is great.
Also, you don't need to cut the wires to relocate the signals. Takes a little longer, but I don't like the idea of cutting/splicing wires.
scooper321
Electrical/Lighting/Alarm
May 31, 2017 07:12 PM
dmarion
Jul 8, 2015 10:05 PM
kizzletruck
Jan 21, 2015 06:53 AM
huskytamer
Feb 27, 2012 02:01 PM
ncbeast
Jan 7, 2010 09:15 AM
