2011, why so quiet?
Old Jun 16, 2011 | 07:17 AM
Osco's Avatar
Osco
Account Deactivated
Cool
Originally Posted by SGT Z
I have a 2011 XL1200C. While the queitness is a little embarassing, someone said it sounded like a Honda , I'd much prefer engine longevity over anything else. I'm an Army mechanic so I know a little somthing about vehicles with 4+ wheels, and I know that performance parts take their toll on an engine. I'm guessing the same is for motorcycles. I'd rather keep the stock exhaust if knocking out baffles and drilling holes is going to result in long-term problems.
Hey SGT,,I got some reading for ya to do,
Knowledge Is power
Read the FAQ page on the Link below:
http://www.nightrider.com/parts/
then go here:
http://www.harley-performance.com/harley-exhaust.html
True, Hi performance means less engine life span BUT
Going Stage one Is not Hi performance. It's just helping the engine, wich
Is Only an air pump breath better
My X14ieD review:::::
The Factory 14.7 EPA compliant AFR Is very very lean.
This produced white chalky plugs on my stocker.
The X14ieD claims an AFR of 14.0
The XieD claims an AFR of 13.8
I have the X14ieD and my plugs are a nice copper color now.
With This I feel safe adding a Hi flow "Baffled" exhaust and or air filter.
I'm no expert, I just could NOT justify all that money for an ECM and dyno time.
$1,000 for a proper stage one just for a single digit Increase in HP and TQ.
what 6 or 7 at best..No Thanks,
If your Installing a 2 into 1 system or removing the crossover pipe that could Induce flat spots
along the power curve and you may need the adjustablity of the PC V or
some other turner to manipulate the fuel tables and or Ignition.
The X14ieD's I Installed really feels good. the Bike Is smoother at all RPM's
My MPG did NOT drop probably because I'm using less throttle due to the
apparent extra power which Is really just smoother power delivery.
The Biggest change on my 08 EFI 1200R was cold start ups.
Before the X14ieD I'd start It,,
get 1400 rpms,,,then 15 to 20 seconds later a single Miss,,
It would almost Kill the engine,,followed buy 30 to 45 seconds of a unsteady Idle
ranging from 1000 to 1400 RPM's.
A steady 1,000 rpm idle would be reached at about 1.5 minutes or even 2 minutes.
After the X14ieD, Imediatly after,,,WOW
Hit the starter,,,rock stable Idle at 1400 rpm's then 20 to 30 seconds later
(45 seconds on chilly mornings) I'd have me a Tach parked on 1,050 RPM's
The needle looked welded to the Tach Face.
That one nasty Miss was all Gone!
I never noticed a ECM "Learning curve",,there may have been one but I was so
overwhelmed by my new smooth power delivery I still say my ECM figgerd
It had died and gone to Harley heavan XD
Here Endeth the Lesson XD
Old Jun 16, 2011 | 07:21 AM
Osco's Avatar
Osco
Account Deactivated
Cool Not mine but a good read,,,,
Plug Reading 101
I have been posting this whenever someone needed help tuning, and it was just suggested that I start a thread with this so that I won't have to repost every time someone needs it.
This method comes from my long term friendship with Brad Urban who until he passed away a few years ago was one of the leading carb builders in the world (The Carburetor Shop), and for a period of about 6 years I went with Brad to one of the different short tracks in Southern California every weekend durring racing season to tune his carbs. For that 6 years his carbs were on cars that heald the track record at every track in Southern California for the entire period, and three of four cars in the trophy dashes were routinely his too. This 6 year time period started while Ascot was still running and continued past the time that Ascot was closed down. Brad was featured in Hot Rod, Super Chevy, and Circle Track regularly, and the world of racing lost a lot with his passing. It is my aim to keep his method alive, because I am not getting any younger myself.
Plug Reading 101
First off, forget everything you think you know from reading repair manuals because that only works on engines with old used plugs and engine problems that are easy for the average person to see on the plug without any special training.
Plugs can be read with as little as two laps on them at the track.
ˇ Start with new, or extremely clean recently new plugs.
ˇ Best readings are taken by running the vehicle at sustained speeds in the range that you are checking, IE: “Wide Open”, Mid Range”, “At or near Idle”, then disengaging the clutch, killing the engine cleanly, and coasting to a stop.
ˇ Overall readings can still be taken without a clean kill and stop, even without new plugs. This is still very accurate, and one of the best tune up tools you have. Just make sure that you have good plugs and by keeping an eye on them as you make changes you can read the effect that the changes made. This just requires a mental track record or a written one.
Where to read them.
ˇ The porcelain is used for reading plug heat range, and timing only. Never try to read fuel mixture off the porcelain.
ˇ The inner wall of the metal shell extending down to where that meets the porcelain is where you read the mixture.
ˇ Engine problems such as oil consumption, etc., are read by going back to your manual. We are only concerned with a good sound engine for fine tuning purposes.
How to read them.
ˇ Timing that has too much advance will show as black flecks on the porcelain. These are flecks of aluminum off the piston due to detonation. Even a good running engine will show signs of minor detonation, but keep an eye on those flecks and if they get bigger and more of them it’s time to look seriously at the timing.
ˇ To determine heat range of your plugs look at the porcelain as it starts to take color. If the porcelain is white to a light tan, the heat range of the plug is right. Remember we are talking a couple of laps so it doesn’t have much time to take color which is why white is acceptable. If it starts looking gray or black possibly even a bit wet looking, the plug is too cold. The more black it is and the more it is wet, the further to the cold side it is. If the plug is dark tan or worse yet getting a burnt black look to it with blisters on the porcelain, then it is too hot a plug. Note the difference between a cold black and a burnt black at the two extremes. They are not the same black by any means. Fuel deposits on older plugs flake off, so don’t confuse that with blistering.
ˇ For reading mixture, read the metal inner wall ONLY.
ˇ The upper ring around the electrode area (as you hold the plug electrode up facing you) is where you read the idle mixture. Correct reading is MEDIUM GRAY. Light gray to whitish gray is lean, dark gray to black is rich, with powdery black being richer yet, then after that it starts to get wet and the black gets flushed off like it was rinsed with gas. (You will see some of this on the intake valve side of the plug and that is not a concern if the color is correct otherwise).
ˇ The lower ring where it meets the porcelain way down inside (you need a magnifying glass and good lighting to see clearly down to the bottom), is where you read wide open throttle. Color readings are the same for all ranges except that the wet flushed off look is only going to be showing at the idle portion of the plug.
ˇ The mid range is everywhere in between that top ring and the bottom ring. Color is again read the same.
To bring this into perspective for the Sportster.
ˇ Stock timing will be acceptable unless it’s broken. I see some specs on mine, so some over advance seems normal, just keep an eye on it over time looking for changes.
ˇ Stock heat range of plug will be good through stage 1 and possibly stage 2. If the compression gets raised too much then you may need to drop to a colder plug, and that will become evident if the porcelain gets dark tan to black and blistered.
ˇ Idle reading will be a function of the mixture screw, and the pilot jet. If that upper ring is light tan or whitish, then open up that idle screw until the engine sounds right (about three turns to three and a quarter out for stage 1). Only consider upping the pilot jet if you can not get it right with the mixture screw.
ˇ Mid range will be a function of the needle, the needle position, and close to idle the pilot jet will effect it too. The Main jet will also effect the mid range, but at the same time it will effect the wide open throttle setting too.
ˇ Wide Open Throttle is mostly the Main jet.
I always work on idle and WOT first. Once I get those in range I take it for a good ride and pull the plugs to double check those two extremes and start working on the mid range which takes more patience.
To fine tune it in any range, do the clean kill in the range in question, then read that section of the plug.
As long as the plugs are reading nice in all the ranges then you can periodically look at them and see that everything is still good. I always take compression and read the plugs every time I do a tune up and I change the plugs out for every tune up too (5000 miles)
__________________
Old Jun 16, 2011 | 10:04 AM
HeritageLover's Avatar
HeritageLover
Originally Posted by balloo
I have a 2008 1200 Custom and have Screamin Eagle Slip On.
It now has a nice sound, but not something that the neighbors will complain about.
Also, you do not need to change anything else when you change the mufflers on Fuel Injected motors
any time you change the exhaust on an EFI engine, you will have to bring it to the dealer for a download to change the air/fuel map. just FYI.
Old Jun 16, 2011 | 10:39 AM
ezmo's Avatar
ezmo
Originally Posted by YOURADHERE
You can thank the EPA/Emissions/Sound reguations for the quietness.
No, you can thank ridiculously loud bike owners for the sound regulations....
Old Jun 16, 2011 | 01:12 PM
HOTLAP's Avatar
HOTLAP
Wrong!
Old Jun 16, 2011 | 01:35 PM
lh4x4's Avatar
lh4x4
All of mine are quiet. But then I am hard of hearing.
Old Jun 16, 2011 | 01:45 PM
honorsdaddy's Avatar
honorsdaddy
No you don't.
If all you're changing is the muffler, no, you do not.
If you're altering the intake and/or exhaust volume (amount, not sound) then yes, it is recommended you re-tune the AFR.
Of course, if HD would use a quality ECM rather than the junk-heap-reject they insist upon stuffing in the bike, then it could automatically adjust AFR for peak performance and efficiency on the fly, just like every car currently sold in the US and damn near every metric motorcycle...
Old Jun 16, 2011 | 02:22 PM
Osco's Avatar
Osco
Account Deactivated
Cool
Wayyyyyy wrong dude,,
The PC III or the PC V
or the V&H fuel pac,
or the TTS master tune,
or the top of the line Thunder Max
or even the plug and play XieD's, X14ieD's and
the adjustable VieD
these all work
Some have Auto tune,,Yep tunes as you ride XD
I've seen a few Dyno sheets with the HD Sert, remaps
no thanks.
Honorsdaddy said It best,
I really dig my Sportster and HD ain't never gonna lay a finger on it.
Old Jun 16, 2011 | 02:30 PM
Osco's Avatar
Osco
Account Deactivated
Cool
balloo,,
All the stock EFI's could benefit from a bit more fuel. they ALL run lean
This will not really hurt the bike.
Adding ONLY baffled slip on's will not hurt the bike.
Adding both the Hi flow Intake and slip on's will make for a shitty runner
without at the very least more fuel.
The X14ieD Is the very minimum for both the SE air filters and slip on
mufflers. Those things just work
Old Jun 16, 2011 | 06:33 PM
Jrock1062's Avatar
Jrock1062
good thread
