Good Day to all. Quick questions as I am in Germany and cannot just go straight to a dealer with any problems.
I have a 2010 883 Iron with almost 500 miles on it. I put the V&H 2into1 pipes on it, Screamin Eagle Breather, and Stage 1 Download.
Issue#1: I checked the oil the other day and there were bubbles in the oil tank. Is this normal?
Issue#2: Yesterday I went to back the bike out of the garage. The bike was off and in gear. I pulled the clutch in and pulled it backwards and it had A LOT of resistance, it did move though. This is the first time that this has happened. I started her up and rode her around the block (bad weather here) and it was fine. Turned it off and it did the same thing. Rolls fine wihen in neutral. Any thoughts or suggestions?
