Dying battery
Old Jul 10, 2011 | 09:45 PM
slipvayne9278's Avatar
slipvayne9278
Well im hoping its the battery, easy quick fix, i have another one im fully charging then gonna have it tested to see if all cells are working, then i will try that one and see what happens
Old Jul 11, 2011 | 12:26 AM
slipvayne9278
Now i feel retarded, how do you get the Chrome battery cover off?
Old Jul 11, 2011 | 06:30 AM
XTsHOG's Avatar
XTsHOG
Don't feel bad I got a chrome cover and I had been trying to figure that one too as I want to put a battery tender lead on but it looks Like I cam get it on the posts wo pulling the battery.
I might be wrong but it looks like you got to unbolt the whole battery case.
Maybe with someone who has done it can jump in.
Old Jul 11, 2011 | 11:01 AM
SIDECAR BOB's Avatar
SIDECAR BOB
been a while since I had my sporty , but trying to rememeber for you guys it either had a tab with a philliups screw or a band type clamp that kinda sat behind the cover beteewn the battery and the cover, take off the seat and you should be able to see them ,If its a tab it was on the bottom or bottom sidews and and think a phillips screw head , b ut been a few year , if i can find my sporty manual ill look it up in a bit to be sure
Old Jul 11, 2011 | 06:32 PM
slipvayne9278
ok figured out the battery cover, put in a new battery drove all day(like 5 or 6 hours) started everytime i stopped, then all of a sudden the bike is constantly backfireing,i dont know why or what would cause that, help please on that, then when got home after riding put a multimeter on the battery to see if everything was ok...nope battery read 11.94 so its still not charging the battery, i always thought if the alternator doesnt work wouldnt the bike die after the battery was drained?
Old Jul 12, 2011 | 08:59 PM
slipvayne9278
I was just reading something, not sure if its true or not, could a weak battery cause backfireing? I only ask because i rode for like 4 hours with no issues, then it just started to backfire
Old Jul 16, 2011 | 10:24 AM
WRAITH's Avatar
WRAITH
Low voltage will cause back firing. Have you purchased a service manual? You will need to re-charge the new battery. Test the battery with a multi-meter. A healthy battery will have a reading of 12.5-12.8 volts. With the engine running at 2000-3000 rpm, you should have 14-15 volts at the battery. If it's less test the stator with the following procedure. At the voltage regulator is a round 2 prong plug connector, remove the locking collar and unplug the stator. Set your voltage meter to AC volts. Start the engine. Holding the stator side of the plug, insert the probes into each side of the socket. With the engine at 2000 rpm the meter should read 38-52 volts AC. If the voltage is less you will need to replace the stator. If the voltage is in the appropriate range, then the voltage regulator could be the problem. If you have to replace the stator, DO NOT use a stock replacement from your dealer. Cycle electric makes a very good replacement for around $100.
Old Jul 19, 2011 | 07:54 AM
slipvayne9278
Default pic added
well here is a pic of the bike, i was told by several harley owners by the description it is most likely the voltage regulator, so i ended up ordering one,they are cheap enough just to buy one and have a peice of mind,even if that isnt the problem,we will see i guess
Old Jul 19, 2011 | 08:41 AM
WRAITH's Avatar
WRAITH
Most people replace the regulator because it is easy to access. 90% of the time it's the stator that has failed. Buy a service manual it will save you a lot of grief. The HD manual is the best but expensive, Clymer is a good affordable alternative.
Old Jul 19, 2011 | 08:53 AM
XTsHOG's Avatar
XTsHOG
Hey slipvayne9278 did you try the test as wraith had suggested?
When it comes to electrical crap, you don't want to *****-nilly replace parts bcuz sometimes something's can be as cheap as a loose connection. When I was a young fry , I once replaced a battery and alternator on a car and in the end it was a bad ground cable that fried on the inside.
