Just bought a Sportster, and am beginning to have problems
A dead spot will draw major current and possibly kill the battery.
I'd b worried about that oil buildup cuz at over 200+ miles it shud be clean as a whistle in there IMO. Mine at 25k looks cleaner.
The easiest way to tell would be to hook an oscilloscope up to it.
Bought my 98 with 7700 on it, rode fine till it hit 10K. Started having a cold knock, then lost power on the front cylinder one day. Had it checked out, the exhaust valve guide was almost completely pulled out of the head. Valve had to be replaced since the rust pitting on the face and stem was so bad it couldn't be ground. Tons of sitting and improper storage did it IMO.
Now that you've got it, ride the hell out of it! Nice scoot
also when it finally catches it sounds like something is slipping
something loose someplace or the starter is cooked I would think
but there is a ton of people on here that know more than I do
wheres Charlie he could probably tell us all what is was in his sleep just by the sound LOL
Jason
This bike is not even broke in. How fast have you ridden it, previous owner or possibly other buyers?
What kind of environment was it stored in?
Just don't run the snot out of it until this oil issue is cleared up.
The low miles makes me speculate someone bought it as a showpiece and basically sat in their driveway revving the fck out of it.
The oil level in the bike is right in the middle between add and full and I have been riding it easy because it is still on its break-in.
The previous owner apparently had the bike and rode it only a short time before deciding that riding wasnt for them.
Twice now after I have shut the bike off and it has a little bit of run-on, where in probably fires 2 or 3 more times after I shut it down then it coughs and dies and the oil lamp illuminates on the gauge. I am wondering if that is the source of the oil (atleast thats what I'm hoping). Is there any other reason for that run-on other then a dirty carb?
The run on or dieseling might be caused by a lean condition in the A/F mixture but at that miles that should not be happening.
I can't think of the carb component but extra gas is entering after shutoff causing the run on.
I'm thinking it's carb/gasket/gas related.
I would also pull those plugs and if they are oil soaked then you got problems if they are white then it's an indicator of a lean condition.
