100/90-19 replacement tire? HELP!
Old Sep 16, 2011 | 01:05 PM
RBar's Avatar
RBar
Default 100/90-19 replacement tire? HELP!
On a XL 883 ('06), could I fit a 110/90-19 on the same rim with enough clearance with stock set-up?
(I am thinking Metzler 110/90-19 to replace the Dunlop HD 100/90-19.)
RBar
Old Sep 16, 2011 | 02:07 PM
cHarley's Avatar
cHarley
Not unless you want to run without the fender. The 110 Metz is roughly 1/3" (.32") wider than the 100.
100/90 -19 TL 57H F 2.50 2.15-2.75 4.25 26.53 507 42 130 .25000 11.68
110/90 -19 TL 62H F 2.50 2.15-3.00 4.57 27.00 584 42 130 .18750 12.79
Old Sep 21, 2011 | 11:32 AM
RBar's Avatar
RBar
Default Good information!
Still, though I have not yet measured, seems like there is well over 1/4" clearance on either side...
BUT...the problem would be the connecting bolts I suppose?
Which tire do you use on your Sporty?
RBar
Doug S
Feb 21, 2011 12:02 AM
Robbie13
Nov 30, 2010 04:30 PM
skintbackfarms
Apr 26, 2009 08:44 AM
GPHDXLC
Jun 30, 2007 11:25 PM
burntrack
Apr 26, 2007 01:50 PM
