New Battery already dead
Old Sep 17, 2011 | 01:37 PM
Booey424's Avatar
Booey424
Default New Battery already dead
I have a 2003 883r. I had to replace the original battery about a month ago. Now the new battery is also dead.
This is what happend:
The original battery seemed to just wind down. I charged it once and it worked. But when I was out riding I stopped for fuel and it was dead. I got a jump and made it home where it was dead again. So I bought a new battery at Wal-mart. I had to put the acid in it, charge it and install it. The new battery worked great for 4 weeks. Today I went out to start it and click-click-click. I put a meter on it and it's reading 10 volts. I have it on the charger again, but I was wondering if maybe the bike isn't keeping the battery charged. Regulator maybe? or the starter going bad? Any help would be great. Thanks
Old Sep 17, 2011 | 05:19 PM
Booey424's Avatar
Booey424
UPDATE
I charged the battery today. The bike started right up. I rode around town, highway and sidestreets. I was oiut for about an hour. Got it home,turned it off, tried to restart it and click-click-click. The battery won't hold the charge. Could it be the stator?
Old Sep 17, 2011 | 05:27 PM
perki48's Avatar
perki48
Its something in your charging system, but not the battery.
Old Sep 17, 2011 | 05:37 PM
SauerKraut's Avatar
SauerKraut
This just happened to me last week. If you have a multi meter perform the folling checks. Check battery volt to insure it has at least 12-12.2 volts. Check stator for continuity with the ignition off it should be 0 ohms.Then with engine running unplug stator plug at voltage regulator. Idle up engine to 2000 rpm AC voltage should be at aorund 45-60 volts AC (20-28 volts per 1000 rpm) much more or less than that, probably a bad stator. If stator checks out and battery holds a charge overnight when removed from the bike, either you have a loose ground or a bad votage regulator. For me it was a bad stator, but I replaced the regulator and battery too becasue my was overcharging, which can fry a regultor and battery.
Old Sep 17, 2011 | 05:50 PM
streetfighter06's Avatar
streetfighter06
Buy a tender at walmart for $20.
Old Sep 17, 2011 | 05:59 PM
SauerKraut's Avatar
SauerKraut
+1 on the Tender.
Old Sep 17, 2011 | 06:05 PM
Booey424's Avatar
Booey424
I have a tender.
Old Sep 17, 2011 | 06:14 PM
cHarley's Avatar
cHarley
A fully charged battery should read 12.8 VDC (Volts DC) with the bike not running.
With the bike running at a fast idle (1500 rpm), it should measure between 13.5 - 14.8 VDC. If it doesn't, then you have a bad stator, regulator, or both.
Old Sep 17, 2011 | 06:35 PM
DENGUY's Avatar
DENGUY
I'm betting stator, they have been dropping like flies on here lately.
Old Sep 17, 2011 | 06:42 PM
TWIN CAM 96's Avatar
TWIN CAM 96
The worst thing you did was buy a battery at Wal mart
