Lowering Front Fender
Old Sep 21, 2011 | 11:49 PM
AaronG87's Avatar
AaronG87
I definitely agree with all of the above it does sit too high but, be careful how much you do lower it. The tire will expand due to the centrifugal force of the tire spinning at normal operating speeds. For the most part this isn't too much of a problem unless you plan mounting it super close. I say get a couple lengths of rubber hose in various diameters from the hardware store and tape them to the tire then, place the fender on top of that to get and idea of what you want.
Old Sep 22, 2011 | 02:16 AM
mreed's Avatar
mreed
Pic finally...
And I DID lower the front fender on The Black Turd (different bike) too much. Well, it was actually perfect but then I changed tire brands and Metzlers apparently expand more than the tires I previously had. My paint caught on fire lol.
Old Sep 22, 2011 | 02:26 AM
tripn88's Avatar
tripn88
couldnt you just ream out the holes so its adjustable?
Old Sep 22, 2011 | 06:04 AM
poisonthesteve's Avatar
poisonthesteve
Just pull the damn thing off dude, I did that and I think it looks so mean. If you get caught in the rain, you're getting wet anyways, so fvck it
Old Sep 22, 2011 | 06:18 AM
WVHogRider's Avatar
WVHogRider
I bought a second fender, chopped about 3/4" out of the side plates, welded it back together, drilled out the rivets, cut out the section under the fender, and welded the side mounts directly to the fender. No pics of it right now as it's still in need of some touch up spot welding from grinding & still deciding on a paint scheme.
Old Sep 22, 2011 | 07:40 AM
Voony's Avatar
Voony
mreed: how did you do that exactly? It really looks good.
posointhesteve: get caught in heavy rain one day and you might change your mind. Not only the water splatters on your face, but it goes on your neck, get inside the jacket and hose down your pants.
Old Sep 22, 2011 | 08:00 AM
mreed's Avatar
mreed
I just drilled the holes higher. I taped a 530 chain on the tire and sat the fender down on it to mark the holes.
Old Sep 22, 2011 | 09:16 AM
Voony's Avatar
Voony
Do you remember how much higher you drilled the holes?
Old Sep 22, 2011 | 10:16 AM
RaceFace's Avatar
RaceFace
mreed, your fender job looks great! The sucky thing about Nightster front fenders is they're shorter and don't follow the contour of the tire like yours does. They flair up at each end away from the tire which may make it look weird sitting closer to the tire.
I'm going to give it a shot anyways and huge thanks on the warning about getting the fender too close. That would suck catching fire like that!!!
Old Sep 22, 2011 | 02:03 PM
TennesseeMustangPerf's Avatar
If you set the chain on the tire and set the fender on the chain, all you will need to do is mark the holes and drill, no need to take measurements.
