Stuck float valve maybe?
Old Oct 13, 2011 | 11:45 AM
dixiedawgg's Avatar
dixiedawgg
Default Stuck float valve maybe?
This morning is off to an epic start. I'm loading the bikes to head to Daytona, and my girlfriend's 03 Sportster, which had been running fine, starts gushing gasoline out the air cleaner every time I start it.
Okay I'm no mechanic and this ain't my bike so forgive my less than perfect terminology. You've got three allen screws that hold the black oval plate to the carburetor. Then there's a hole (looks like a screw hole but isn't) at about 10 o'clock I guess. The gas is coming out of there, whenever the bike is running.
Sound like a float issue?? I got the bike trailered and I guess I'll be working on it at the friggin campground the first day instead of riding.
Old Oct 13, 2011 | 11:53 AM
soft 02's Avatar
soft 02
What year is it?
Old Oct 13, 2011 | 01:29 PM
Scuba10jdl's Avatar
Scuba10jdl
That hole is a bowl vent hole. It equalizes the pressure in the bowl to atmosphere. If you get over/under pressurization, it will mess with your fuel delivery.
The fact that you are getting gasoline spraying out of it leads me to believe you are right in thinking your float is not adjusted right, allowing gas to fill up and get pushed/sloshed out of the hole.
Old Oct 13, 2011 | 03:35 PM
Bagger Jim's Avatar
Bagger Jim
Try tapping the float bowl with a screw driver handle. Half the time it will cute a stuck float.
Old Oct 13, 2011 | 03:38 PM
Bagger Jim's Avatar
Bagger Jim
Sorry, I meant "cure" . Darn phone keyboard.
Old Oct 13, 2011 | 03:40 PM
soft 02's Avatar
soft 02
+1 for the love tap method.
Old Oct 17, 2011 | 09:02 PM
dixiedawgg's Avatar
dixiedawgg
Yep it was the float. I smacked the **** out of the carb a few times with a rubber mallet, which didn't fix it but made me feel a little better.
Pulled the bowl off, flicked the float about fifty times in rapid succession, put it back together and it worked fine.
Thanks guys!
TheZombie
EVO
11
Jan 20, 2015 09:43 AM
SGT Rock TN
Exhaust System Topics
Jan 23, 2014 04:11 PM
capriceguy
EVO
Apr 7, 2012 08:34 PM
danktat
Aug 27, 2009 03:17 PM
pococj
Road Trips
Dec 27, 2004 12:59 PM
