how much for a 883-1200 conversion?
Old Oct 19, 2011 | 11:07 PM
Mcnasby's Avatar
Mcnasby
Default how much for a 883-1200 conversion?
I'm looking at bikes on ebay and keep seeing 883's. would it be worth it to buy one then get the 1200 conversion? i heard they are faster after the conversion then a stock due to gear ratio.
Old Oct 19, 2011 | 11:52 PM
ItsTomFromNorthJersey's Avatar
if you search you will find plenty of information on this topic.
Old Oct 20, 2011 | 12:31 AM
TWIS1UP's Avatar
TWIS1UP
Hell, NRHS has 1250 kits, cylinders included, for $700.00. You can bolt it right on!
Old Oct 20, 2011 | 01:12 AM
tjae's Avatar
tjae
I have always thought it is best to get the 883 and convert, but you have to remember that you don't get the convertion money back on re-sale.
Old Oct 20, 2011 | 02:05 AM
mhenry's Avatar
mhenry
the stealer I called (so i dont void anything) said 3300 dollars for there job they recomended a new AC, dyno tune, the power commander and the cylinders plus new pipes (3300 included cost of vance and hines straight shots) so 3300 at chandler HD
Old Oct 20, 2011 | 06:20 AM
RK05's Avatar
RK05
$3300 should get you a Very fast sportster if you spent that kind of money at any Indy shop compared to the Stealer!
The MoCo whould have to prove what went bad to voild your warrenty.
Old Oct 20, 2011 | 07:59 AM
883_dave's Avatar
883_dave
$2200 parts and labor for the SE 1200 conversion kit around here. $1000 more if you want cams with that.
Old Oct 20, 2011 | 08:03 AM
dwagar's Avatar
dwagar
883 gearing will make it quicker, not faster. You will have higher RPMs at a given speed (compared to 1200 gearing).
Lots of options on a conversion, can you install it yourself, set a budget and stay within it.
Old Oct 20, 2011 | 08:30 AM
aklim156581's Avatar
aklim156581
BUT it does NOT include the the heads though. You reuse your 883 heads. Kind makes it an apples to oranges thing. I believe it costs more once you add the 1200 heads.
Old Oct 20, 2011 | 08:34 AM
aklim156581
In THEORY, yes. They can void your warranty and you can fight it. Reason? You made the bike do something WE didn't design it for. BTDT with my cars before. Again, they can deny and you can fight it but is it worth your time?
I go by a simple rule. You mod, no warranty. If you can't live with that, don't mod.
