need help,tail light not working...
Old Oct 22, 2011 | 06:33 PM
frank1200N's Avatar
frank1200N
Default need help,tail light not working...
i have a 2008 nightster, and my tail light doesn't work when i press on my foot brake( rear brake), but it works when i use my front brake lever
Old Oct 22, 2011 | 06:41 PM
streetfighter06's Avatar
streetfighter06
My 06 is the same. Broken rear brake sensor. fvck it.
Old Oct 22, 2011 | 06:45 PM
frank1200N's Avatar
frank1200N
my rear tire was just replaced a few weeks ago, i guess they hit it, thanks
Old Oct 22, 2011 | 07:57 PM
HarleyScuba's Avatar
HarleyScuba
The rear brake switch is pressure activated via the hydraulic brake line. The switch unit is tucked behind the rear master cylinder (you'll see two wire connectors attached). They go out anywhere from 2-10 years. Fairly simple job to put in a new one, but bleeding the rear brake-line afterwards is a little bit of a task. It's probably a coincidence that your tire was changed.
Old Oct 23, 2011 | 02:24 PM
frank1200N's Avatar
frank1200N
thankx bro.
fugno
Apr 28, 2018 01:40 PM
SDozier
Feb 25, 2015 09:48 PM
longhaul-2007
Sep 29, 2013 12:16 PM
RoadKingHellas
Jul 28, 2012 04:09 PM
fasteddie
Jun 5, 2009 02:32 PM
