$30 mini "solo bag"
Old Dec 12, 2011 | 05:57 PM
streetfighter06's Avatar
streetfighter06
How did you mount it to the swingarm with the bag strap being horizontal?
Old Dec 12, 2011 | 06:07 PM
Brion B's Avatar
Brion B
Would also like to know and see how it mounts.
Old Dec 12, 2011 | 07:50 PM
Moya305's Avatar
Moya305
Will that tool bag fit even if you have passenger pegs already mounted on? Ya'll think it'll fit? Very creative place to put it, looks great.
Old Dec 12, 2011 | 10:26 PM
Voony's Avatar
Voony
I would do the same if I didn't relocate my license plate to the swing arm
Old Dec 12, 2011 | 10:34 PM
solo48's Avatar
solo48
just moved mine without issue.. the straps on mine have the option of vert. or horiz. so i just changed them to vert. and strapped her on there. i have pass. pegs and no clearance issues i can see so far, although my wife wears a 5 1/2- 6 so that might not be the case for others... no pics yet, like i stated previously( litterally just changed location) but will try to get some up soon
Old Dec 13, 2011 | 06:01 AM
hdiron421's Avatar
hdiron421
mine has a steel bar sewn into the back from end to end and has a hole in the center and came with a bolt and nut. i made a offset "L" bracket and bolted it under the bolt that holds that brakeline clamp and then bolted the bag to it. i also ran the straps around the arm for backup incase the bracket breaks...
Old Dec 13, 2011 | 07:02 AM
Moya305's Avatar
Moya305
Solo48 you said you had that bag mounted with the passenger pegs installed, can you post a pic if you get a chance? Thanks a lot.
Old Dec 13, 2011 | 07:29 AM
solo48's Avatar
solo48
was up all night doing my wire tuck/ ignition/ coil relocate/ tank lift... tidyin up now i will roll the ol girl outside and take some pics here in a few!
Old Dec 13, 2011 | 01:07 PM
Moya305's Avatar
Moya305
Thanks man!
Old Dec 14, 2011 | 10:15 AM
wrussi's Avatar
wrussi
used zip ties (4 total) they go around the the strapholders and around the swingarm. it held pretty tight by them. it doesnt even move if you try to. i'll try to take a picture with more detail
