Mid Controls VS. Forward Controls: Preferences
A Sportster will never be a sport bike, and should never be a sofa (that's what BT's are for). However, you can un-Harley a Sportster and make it a good performance bike with good handling capabilities (the true nature of the Sportster). A proper suspension and mid or rear sets are critical for aggressive cornering.
If you think you are cornering aggressively with forwards, apes and 10" shocks, then you don't understand the concept.
If you did indeed read my posts, and more importantly understood what you read, you wouldn't be making the fundamental mistake you are making. I am not advocating hardware as an instant solution (or as a solution at all), but technique as the solution. Proper hardware makes proper technique possible.
Get it?
http://youtu.be/qoMQOlw-bts
I think if you had some mids so you could pivot steer, you would have held a better line (like the guys in front of you) when you hit the double yellow lines a few times. Pivot steering at such shallow lean angles would also help reduce the unfortunate scraping of parts/boots.
In fact, this video perfectly illustrates the problems associated with rolling through curves cruiser-style.
Thx Rog.
Cornering is not just point and shoot, there are many factors and techniques to do it right. The bike setup is pretty critical to success in using the techniques I have been referring to. But if your thing is just cruising, have at it, just don't confuse what you are doing with aggressive cornering.
As a personal note to Rog; while I am responding to your post, I am not necessarily responding to you. I am using the general "you" in my responses.
I was curious enough, and thought, "What da Hell. Maybe I'll learn something." After all, I'll ride anything with two wheels. Maybe it'll help. Somehow. So, I gave it a Google and spent a little time reading.
If you want any significant direction change, you need counter-steering. I qualified that statement with significant because, yes, you can lean to one side and weight a peg to influence the direction of a bike, but the result will be minimal, if any. Particularly at speed, with your wheels' and drivetrain's gyroscopic effect.
Here's a thread where, presumably, the Kieth Code chimed in about pivot steering. Post #24, member name "codedog". He goes on to Say, in post #30, "I wouldn't touch the peg weighting debate with a ten foot poll (sic)." Pivot steering, in a nutshell, is simply anchoring your body. I'm not certain why it's called "pivot steering". It should be called "anchor steering." Here's an example I'll paraphrase from the above mentioned thread:
Put a scale on a wall. Put your left hand on the scale and raise your right foot. Push on the scale with you left hand. Now, keep your left hand on the scale, put your right foot down and raise your left foot. Push on the scale using your left hand and right foot. This results in a greater force against the scale.
Pivot steering, then, is bracing your outside leg between the peg and the gas tank in an attempt to gain easier leverage on the bars. It has nothing to do with weighting the outside peg. I'm not sure how the word "pivot" came to replace the words "planted", "braced" or "anchored".
That's how it went for me. Did you try getting through Willow Springs with your hands off the bars, yet? Pics required. LOL
Reference thread: http://www.therevcounter.co.uk/uk-mo...tside-peg.html
I am a disappointed that, with the entirety of the Internet at your disposal, you still didn't figure it out - even with Keith Code to describe it, you still managed to confuse it with peg weighting. You really should learn how to ride a motorcycle one day.
My apologies for being so pissy, and I will blame it mostly on the wine, but in reality I get a little annoyed with people who try to be clever and fail.
I'll try to find a YouTube vid for you tomorrow, or maybe some cartoons to make it clearer. Right now, I need to refill my glass.
