Draining the oil
Old Jan 2, 2012 | 02:06 PM
RZA's Avatar
RZA
Any ideas why It wouldn't start up.
Old Jan 2, 2012 | 02:20 PM
CanuckSporty's Avatar
CanuckSporty
What is the oil level on your dip stick? You want it no higher than the 3/4 full mark, or you run the risk of oil pukeage.
Old Jan 2, 2012 | 02:27 PM
RZA's Avatar
RZA
Originally Posted by CanuckSporty
Where is the oil on your dip stick? You want it no higher than the 3/4 full mark, or you run the risk of oil pukeage.
I will check when I go home today. Where would the oil come out if there is to much oil?
Old Jan 2, 2012 | 02:30 PM
CanuckSporty
It's never happened to me, but I have heard of oil coming out through the intake when the tank is too full. Probably backs up through the breathers.
Old Jan 2, 2012 | 03:16 PM
RZA's Avatar
RZA
I think I will go home and drain some oil and see what happens. Thanks for the inputs.
Old Jan 2, 2012 | 03:29 PM
John Harper's Avatar
John Harper
I don't think you want to drain the oil lines to the pump. It may lose prime because of trapped air. My 1991 XLH has a fitting on the downstream side of the pump to allow pump to prime if that happens. I've not had it happen, but it is mentioned in my service manual.
I just drain the tank, refill. Take off filter, add some oil to new filter, install, and drive.
John
Old Jan 9, 2012 | 05:58 PM
RZA's Avatar
RZA
Smile
Open the garage this sat got the bike back running again These is how it went down. Check the dip stick had way too much oil in it so drain it out now its about 2 inces above the fist mark. Went to start it didnt want to start no backfire but still didnt start so moved on to the plugs took the plugs off gap them again put them in said a prayer and my bike was alive again. Thanks for all the tips and advise. Moving on to the next project jiffy stand.
oomchu
Apr 19, 2023 07:07 PM
Ric Jelfs
Feb 22, 2017 08:19 AM
galaxyfe
Jan 4, 2016 10:26 AM
eggroll
Apr 21, 2007 01:25 PM
FORDTUFF
Apr 16, 2007 11:04 PM
