Concerns about Air Shocks
Old Feb 16, 2012 | 05:23 PM
Superfly3176's Avatar
Superfly3176
Originally Posted by damnation9
getting RK shocks for my Nightster and want to put the valves on each one,don't want the hoses. What type do I need, I mean the size and fitting,and where can I get them?
1/8 inch pipe threaded schraeder valves. Napa or the internet are the only place I found them. Napa had to order them for me. make sure you use teflon tape to seal them.
Old Feb 16, 2012 | 05:39 PM
JAT's Avatar
JAT
I see so much about the RK air shocks on ebay, etc. Why would you do these instead of the Progressives? Is it a money thing? Same quality for less?
Old Feb 16, 2012 | 06:07 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Misbehaven
I bought some shocks on ebay with all the lines and valves for $85.00, brand new take offs from a 2011 SG.
I am getting ready to put the 12" SG shocks on the wife's 2008 883L. Because the 12" will raise the bike up an inch I was planning on the 1" lowering blocks but was told that the ride gets worse because the change in the angle of the shocks. But after what you said I will go with my plan. The bike in stock form was just right for her height wise. But after the change to a Mustang solo wide touring seat it raised her up a bit. Thinking that we will have to have the seat sent to Mean City cycles to be cut down and narrowed up in the front.
I don't know all the math of it, but with the lowering block the lower shock mount is further back it seems the shock works a little more with each road irregularity giving it a smoother ride. Could be some other reason altogether...but it is definitely a better ride for me on my bike.
Local auto zone had them on the shelf in Memphis a few years back when I got mine.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Feb 16, 2012 | 06:33 PM
WhiskeySierra's Avatar
WhiskeySierra
My local Ace Hardware had them for less $3 each.
Old Feb 16, 2012 | 07:19 PM
edgeofinsanity's Avatar
edgeofinsanity
Yep, look for 1/8 NPT. I've heard some guys say they are finding them in hardware or auto parts stores with the air tank fittings. I wrapped mine with teflon tape, don't know if it's necessary, but it can't hurt.
I used the lowered street glide shocks on my Custom, only 1/4" height difference, but with the shocks at an angle, I couldn't tell a difference in ride height. I could tell a difference in ride, made a huge improvement.
Old Feb 17, 2012 | 08:13 AM
Turbinesaint's Avatar
Turbinesaint
Just picked up a set of 13" RK's for $50 shipped. Have been going back and forth between selling the 13's and getting 12's or using the 13's and a lowering block kit (I feel like a broken record). Might just save my $$ and send them to Phoenix Customs and have the 13's cut down to stock height. I figured for all that money, I could've just saved me all the hassle and bought a set of Progressive 412's but have heard that there is nothing like the ride on the air shocks.
Old Feb 17, 2012 | 09:46 AM
jbyun's Avatar
jbyun
Just put on the RK 13''s and test it out without a lowering block kit...many have done that with no problems.
Give it a month or so to see if you like it. If you don't, then either get a lowering block kit or you can just find some Street Glide 12'' shocks. At the price you got your 13''s for, you can easily get your money back by selling it on Ebay or on this forum.
Also, check any local HD dealerships. The one in Raleigh has a spare part department and I picked up my barely used SG 12'' shocks for $50.
For my set up, I just sat on the bike and installed the plugs on the air shocks and am running with 0 psi. It seems to work fine for me at 160 - 165 lbs. You might find that running 0 psi works for you as well. Start cheap, test things out and add stuff if needed instead of just buying everything at once and later finding you may not need air in your shocks. YMMV.
Old Feb 17, 2012 | 05:15 PM
JAT's Avatar
JAT
So why not the Progressive 416's? Again, is it just a $$$ thing?
Old Feb 17, 2012 | 05:54 PM
WhiskeySierra
You can also adjust the ride with air shocks. More air, stiffer shocks; less air, softer shocks.
Old Feb 17, 2012 | 09:03 PM
JAT's Avatar
JAT
I think the 416's are air shocks.
