Outlaw Breather Bolts
Old Dec 11, 2013 | 10:37 AM
AWS2111's Avatar
AWS2111
I've been using them for 7000 miles and haven't cleaned the filters, no need really. They work great and look great.
We've had some lengthy discussion about them before, if you can chew through the fat on this thread there's some good info.
https://www.hdforums.com/forum/sport...r-options.html
Old Dec 11, 2013 | 11:09 AM
rsking45's Avatar
rsking45
I'm not questioning if the breathers work or not themselves,I'm wondering if they will work with What on my bike
Old Dec 11, 2013 | 11:27 AM
AWS2111's Avatar
AWS2111
It looks like that system has a setup that channels the breathers back into the air cleaner and throttle body so it seems that it won't work.
Old Dec 11, 2013 | 01:58 PM
cHarley's Avatar
cHarley
No, if back-plate of your A/C is attached using the breather bolts. Yes, if it's not.
Old Dec 11, 2013 | 02:10 PM
jdub099's Avatar
jdub099
Not true. I used these breathers with an Arlen Ness backplate.
Old Dec 11, 2013 | 02:21 PM
cHarley's Avatar
cHarley
If that's the case, then your breather bolts weren't being used for the physical attachment and you have something else (bracket) that's holding the carb/TB in the intake manifold.
On a stock A/C, the back-plate holds the carb/TB to the manifold via the breather bolts.
Old Dec 11, 2013 | 02:38 PM
jdub099's Avatar
jdub099
There is no additional bracket aside from the backplate. The breather bolts went through the backplate and then there were three stand-offs that went through the backplate into the TB. That's it.
Here's some pics of the Arlen Ness setup. Just replaced the two banjo bolts going into the head with the DK Breather Bolts.
Attached Thumbnails Outlaw Breather Bolts-5.jpg   Outlaw Breather Bolts-bs_newfilter.jpg
Old Dec 11, 2013 | 03:06 PM
BMCsteve's Avatar
BMCsteve
Wonder if you can use these with the Figure Machine intake
Old Dec 11, 2013 | 03:39 PM
cHarley's Avatar
cHarley
Unlike the stock A/C, you have a mounting bracket (that may be part of the back-plate), like I referenced above, that's holding the TB in the intake manifold, you can see the bracket "ear" in the 2nd pic, attached to the left breather bolt. On the stock A/C there is no bracket, the breather bolt itself makes the back-plate mechanical connection.
Old Dec 11, 2013 | 03:55 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
The word 'Breather' may be a misnomer , probably 99.9% of the air is out, not in. There is a one way poppet (umbrella) valve leading to these exits that has a filter/baffle system.
