29.5" drag bar w/ stock risers, ss brake line length?
Old Feb 20, 2012 | 06:51 PM
562IRON's Avatar
562IRON
Lightbulb 29.5" drag bar w/ stock risers 2012 883 *update-installed*
Im planning on running this setup on my '12 iron 883... 29.5" drag bar with a 15 degree sweep/0 rise on stock risers.
Here is the link to the bar:
http://www.debrix.com/29-5-Drag-Bar-...25-0879-vt.htm
I plan doing the brake line, I don't want to deal with the stock line kinking a little (though I know most of you don't have an issue with this). What length do you think will work for my application? Will a stock length ss braided line suffice for how it should bend down towards the wheel?
Also, if any of you know recommend other 28-29.5" drag bars with no rise/10-15 degree sweep/knurled, (preferably less than 15 deg sweep) would be awesome! I wouldn't mind internally wiring them them either, actually I'd rather do it that way.
Thanks everyone
************UPDATE-Drag Bars on!
I got the bars on, passed on the ss lines, and got new grips instead. See below for pics.
-Debrix 29.5 Drag bars (I drilled holes in there to internally wire them)
-Joker Machine Clamp with slot for stock indicator strip
-Auto Gem baby bullet signals
-DIY speedo relocation with autometer clamps
-Flipped mirrors
-Black Kurykan ISO Grips
-DIY Turn signal brackets-used this link as a general guide since I used different signals
before/after
powder coated:
diy signal bracket:
Overall impression, love it!!1231!! I naturally sit a little more forward, so the drag bars fit my riding stance perfectly. The housings on the drag bar also clear the tank from lock to lock with room to spare. And the grips are so damn comfortable, it's amazing.
Old Feb 20, 2012 | 07:10 PM
streetfighter06's Avatar
streetfighter06
Dude you don't need anything to work with those bars. Install them, save the cash and be done with it.
Old Feb 20, 2012 | 07:42 PM
tripn88's Avatar
tripn88
I measured my stock length and it was roughly 40 inches.
Old Apr 8, 2012 | 02:05 PM
562IRON's Avatar
562IRON
Updated my initial post, got the drag bars on! passed on the ss lines....got grips instead. Thanks for the advice guys
Old Apr 8, 2012 | 02:36 PM
blindrocket's Avatar
blindrocket
Looks dope. Good job.
Old Apr 8, 2012 | 07:13 PM
562IRON's Avatar
562IRON
Thanks man, learned a lot doing this
Turret_plug
Mar 10, 2015 01:34 PM
RMS-138
Jun 2, 2012 01:25 PM
djbirri
Dec 27, 2011 01:48 PM
rockon
Jan 23, 2011 12:58 PM
alrom999
Aug 28, 2008 07:52 AM
