Battery?
Old Feb 21, 2012 | 04:49 AM
B1broc's Avatar
B1broc
Stage II
Default Battery?
So i wrapped my 09nightstermoms pipes and put them on my bike and its been sitting on my trickle charger it fires right up smoke rverywhere cuz of the wrap three days go buy i pull it off the stand take it out in the drive way turn the key here it spray. Then hit the start button absuletly nothing no clicks or nothing horns loud and lights are bright wtf?
Old Feb 21, 2012 | 04:53 AM
cavalier2000's Avatar
cavalier2000
When you press the start button do the lights go off?
Old Feb 21, 2012 | 05:01 AM
B1broc's Avatar
B1broc
Stage II
Nope they stay on nothing hits man it just started three days ago ive never had a problem
Old Feb 21, 2012 | 06:14 AM
cavalier2000
a few things.
Are you pulling the clutch?
is it in neutral?
flip the kill switch on the handles back and forth a few times.
check your fuses
I had this problem on my sport bike kinda of a last thing, so you have a sensor on your kick stand. my sport bike wouldn't start if the kick stand was up.
Old Feb 21, 2012 | 06:46 AM
cHarley's Avatar
cHarley
It may or may not be related, but you should never leave the battery on a trickle charger, it will cook the battery. You need to use a float type charger, ie Battery Tender.
Old Feb 21, 2012 | 06:53 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Testing Battrey
Simple battery test - (using volt meter)
battery at rest - 12.9 volts
battery while starting - volt drop no lower than 12.2 volts
battery w/high idle - 14.2 volts
a battery at rest that measures 12.7 volts is 25% discharged!
a high voltage drop at start would indicate a weak battery
a low charge rate at high idle would indicate a weak charging system
Make sure all your connections are clean and tight. Beyond battery you would make sure you have juice down to the starter (test light) and then be working on the starting system.
Quark1968
Oct 16, 2021 04:57 PM
FXDXJimmy
Dec 11, 2012 02:28 PM
alwyslpy
May 30, 2012 10:16 PM
Down2Ride
May 12, 2011 11:26 AM
jacknthebox
Jul 24, 2010 11:12 AM
