My 48, current state.
Stupid Canadian version...
Had a hard time deciding on what seat to get, not a fan of the stock one.
Well I finally bit the bullet and ordered the roughcraft solo seat, just couldnt make myself like the other ones.
I was torn between that and the new Lepera 48 Barebones.
But on a positive note, RC is suppose to have a matching pillion in production soon for it.
Heres a current shot of my bike with,
Bassani ProStreet Exhaust, in black ceramic for mid controls.
Figure Machine XLFLOW-R4 AirCleaner, in gloss black with machined ribs.
Figure Machine Sidemount LED Licence Mount, in gloss black
Chopped rear fender (Canadian) , run/turn/brake module
Swapped out the forwards for mids
Ditched the upper and lower belt guards, reflectors and the front fender
Relocated signals to lower tree, but debating putting them down on the forward control mounts... or losing them all together.
Probably going to swap the bars for some friscos or narrow z bars.. haven't decided yet.
Just need my seat to arrive and decide on what tuner to get, torn between the Power Commander V and splurging for the PowerVision.
Then ride the **** out of it for the summer.
Yeah I seen those, nice bars but they're not black.
Thanks though,
I ran friscos on my last bike and really liked how the felt.
Probably get them again and hack an inch or two off each end to keep things narrow.
License plate mount is a Figure Machine piece. Top quality work, and great to deal with. Had to get them to make it 5x8 instead of the standard 4x7 for my Canadian plate, did it at no extra cost and shipped the next day.
Have the optional LED light, can get any color but I stuck with white. Also my favorite part is it can be mounted horizontal or vertical, just in case I get heat from the cops.
The following link as quite a bit of info on doing wire tucks, pictures, video and step-by-step instructions.
http://www.facebook.com/DKCustom?sk=notes
DKCustomProducts.com
You're looks amazing...
I did a wire tuck without a tank lift. You will need to relocate the coil and ignition but then pull off all the plastic and use electrical tape and tie wraps to tuck everything underneath.
Check it out:
https://www.hdforums.com/forum/sport...-a-noob-4.html
