Risers help
Old Feb 29, 2012 | 09:48 PM
The Last Gunfighter's Avatar
The Last Gunfighter
Default Risers help
Hey guys I know that I definetely need some risers, but I'm still pretty much a newbie, I'm riding an Iron 883 '12 what would I need to know before I jump on this? I was considering something like this
http://www.jpcycles.com/product/214-227
So as far as install is this something that I could do myself? It seems like a simple bolt on job. What do I need to know before I jump on this? Or what should I consider?
Old Feb 29, 2012 | 10:12 PM
Swampdoc's Avatar
Swampdoc
Risers are pretty easy to put on. The main thing that you need to keep in mind is that the pull back risers will change the angle of your speedometer since the speedometer (not sure about 2012's but on other models) mounts to the risers. On my 08 with pullback risers the speedometer was almost vertical. I got around it by mounting the speedometer above the headlight eyebrow. Just something to keep in mind if you are wanting pullbacks. I really like my pullback risers though.
Old Mar 1, 2012 | 02:02 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
They are a pretty straight-forward install on your Iron.
Another option, that is even easier, is to get riser extensions. You already have a couple inch rise on your stock set-up and you can get extensions from 1" up to 3" in 1/2" increments.
This is less expensive, MUCH faster, and gives you more flexibility in getting your handlebars right where you want them.
I think the first thing you should consider is exactly where is the most comfortable location for your grips to be.
Finding the perfect handlebar position for You-
This is the way that has always worked for me to get the most comfortable handlebar position-
Sit on your bike
Have someone hold it up straight for you
Put your feet on the pegs
Close your eyes
Put your hands out to where it is most comfortable to hold them
Open your eyes...where ever your hands are, that is where you want the handlebar grips to be.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Mar 1, 2012 | 07:21 AM
XL50#674's Avatar
XL50#674
My bike has the 4" pull back risers on it and the gauges were 100% vertical and looked bad. I also mounted them to the eyebrow and it looks much better. I wish my bike had the stock risrers as I would love my drag bars to be lower,
Old Mar 1, 2012 | 07:51 AM
131tman's Avatar
131tman
4.5" Pullbacks - stock cables
Old Mar 1, 2012 | 08:40 AM
dwagar's Avatar
dwagar
If the risers are round, you can use a couple of cable clamps to mount the speedo bracket.
The pullback risers I bought happened to be oval shaped. Maybe that's a stronger design, but cable clamps won't work.
Mounting on the eyebrow worked, except I'm running the dual gauge (tach and speedo), and it won't clear my windshield.
Old Mar 1, 2012 | 10:52 AM
Slider2010's Avatar
Slider2010
I have the DK Custom 2" Stealth Risers on my Nightster and they are awsome... you cant even tell they are not a part of the Stock risers unless you really look
Old Mar 29, 2015 | 08:16 PM
Roorat60's Avatar
Roorat60
How do I mount the speedometer on the eyebrow? I have a 2014 iron with OEM 4 inch curved risers and a vertical speedometer now. I have a detachable windshield and want to keep the speedo near original position.
Thanks.
Old Mar 29, 2015 | 08:25 PM
Roorat60's Avatar
Roorat60
Sit on your bike
Close your eyes
Will these risers work on a 2014 iron AND not impact the clamp or angle of speedometer?
Old Mar 30, 2015 | 12:23 PM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Yes, the Riser Extensions will work for your 2014 Iron, and they will not impact the angle of the speedo
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
