Front Brake lock up!!!
Old Mar 21, 2012 | 09:33 PM
John_K's Avatar
John_K
Originally Posted by WVHogRider
I believe I found the culprit.....Yep, master cylinder plunger not returning. Found purple jello thoughout the bottom of it. Used the brake bleeder to suck out majority of the crap, then shop-vac'd out the pieces I found sitting in the master cylinder valve/plunger hole, and then bleed the brake. I used the remainder of the DOT 5 bottle that I used last spring. However, the fluid that bled out was mainly amber with no bubbles at all. Going for a maden voyage right now!!!!!
The jello you found is a result of mixing DOT4 and DOT5... unless your bike is a rubbermount you should be using DOT4!
If you want to use DOT 5 your system has to be purged absolutely clean, you will likely have more jello throughout your system.
Here are the details you should know before you procede any farther.
Old Mar 21, 2012 | 10:22 PM
WVHogRider's Avatar
WVHogRider
I wasn't trying to mix. It's not a rubber mount, but the master cylinder says DOT 5 which is why I used it....I'm probally just going to tear the whole system apart and rebuild. Yes, I know of mixing DOT brake fluids resulting in the jello just like mixing the green radiator fluid with the orange in vehicles.....Both result in jello!!! Thanks though.
Old Mar 21, 2012 | 10:57 PM
John_K's Avatar
John_K
Wonder why the master says DOT 5? did somebody swap the hand controls from a newer model maybe? Sounds like you have a little work ahead. Good luck brother, glad this didn't turn out worse!
EDIT: good lookin scoot BTW, I like those pipes
Old Mar 21, 2012 | 11:59 PM
Scuba10jdl's Avatar
Scuba10jdl
2003 and prior Sportsters use DOT 5.
In fact, DOT 5 is "For use in all models (except '06-later VRSC, '07-later XL, '08-later XR, '06-later Dyna and Softail, and '05-later Touring models)" according to the Motor Company.
Old Mar 22, 2012 | 12:23 AM
John_K's Avatar
John_K
My mistake, thanks for the clarification! Guess I should research a little before I make assumptions like that
Old Mar 22, 2012 | 06:31 AM
WVHogRider's Avatar
WVHogRider
Anybody know the part number(s) for the master cylinder & caliper rebuild kits? The GF grounded me from the bike this morning until I get this fixed, and she made me drive the mommy-mobile, (mini-van).
Old Mar 22, 2012 | 06:34 AM
WVHogRider's Avatar
WVHogRider
Thanks. I'm the original owner, and no, to me switching out the hand controls.
Old Mar 22, 2012 | 07:55 AM
LucyOnBlack's Avatar
LucyOnBlack
MOMMY-MOBILE!!! OMG! Somebody help this guy! lol
Old Mar 22, 2012 | 10:00 AM
defender77's Avatar
defender77
6th Gear
Call it the *******-wagon instead. Why else would they come stock with tinted windows and bench seats? Good luck on the rebuild...I know my 1200R only has 3500 miles on it, but not sure if it's been done at all. Buying used can be scary. The brakes do feel good on it and with dual discs on mine, it stops pretty hard...not like a sport bike, but good for anything but trick riding.
I'm not about to attempt stuff like that...dangerous enough watching for mommy-mobiles out to kill me.
Old Mar 25, 2012 | 05:05 PM
brandonbk's Avatar
brandonbk
Stage I
Jumping on this thread as I'm having this exact issue with my '06 Fat Boy. Same symptoms - drag started a mile from home at ~20mph, which stopped me in my tracks. Bled the front brake to release pressure, and was able to get it back to my garage.
I found a lot of crud in the master cylinder reservoir, and discovered that the brake fluid would not transfer down into the line when bleeding with a MityVac. This pointed towards the master cylinder being clogged, so I purchased the rebuild kit, cleaned everything out well and re-assembled. Brake fluid now freely transfers.
After bleeding to remove air, I went for a short test ride. Within a block of where it happened last time, the front brake locked up again. So, I'm now at a loss - thinking the caliper needs to either be thoroughly cleaned or replaced.
