I've seen some pictures on the forum of Sportsters with (big twin?) tanks. Does anybody know what tank models people are using to get the tank mounted Speedometer?
I want to get rid of the riser on my 05 custom. Thanks, JF
The scoot in my sig pic has a Sportster specific tank from Midwest Cycle Supply (www.midwest-mc.com). Part number 20-36 is for 96-03 models but you should be able to adapt it to a rubber mount if that's what you have. Purchased it through Jireh Cycles for about $135. A word of caution, buy the screw cap version. I bought the camlock gas cap version and they leaked like a sieve. Ended up welding in some screw cap bungs.
Your stock speedo fits into the dash, and your ignition switch wiring easily converts to the dash mounted switch. I had to move my coil, though. Ended up mounting it on the left side by the choke cable, same place as on a Dyna.
I've had it for about 1-1/2 years with no problems. I soldered the crossover stems closed because fuel goes from side to side without a crossover tube anyway. My bobber started out life as a 99 1200S, so your mounting and mine will be the same. The tank itself bolts right up to the stock docking points. It's a pretty straightforward process. I would definitely buy another one if I do another project.
Have the people who "warned" you about these tanks actually had one, or is it all heresay? It's the same gauge steel as a stock tank.
Well I tried to order a Fat Bob tank for my 99 and they are back ordered with no ETA, guess thats why they are priced $350 less then other suppliers? New price is $169 but no ETA
