Help with jetting
Old Apr 24, 2012 | 01:25 AM
Vdoubleyou's Avatar
Vdoubleyou
Thanx to forum thanx to community
Old Apr 24, 2012 | 07:06 AM
mrfikser's Avatar
mrfikser
this may sound weird but the first thing I would do is dump the gas and clean the filter in the tank,then fill it up with new gas...then check the intake gasket (the ring behind the carb)....and blow out the fuel line while you are here....
Old Apr 24, 2012 | 03:02 PM
Vdoubleyou's Avatar
Vdoubleyou
Will try. By filter in tank you mean my petcock I dont think this bike has any other filters
Old Apr 24, 2012 | 03:26 PM
cHarley's Avatar
cHarley
You have to remove the petcock from the tank to expose the filter.
Old Apr 24, 2012 | 03:37 PM
mrfikser's Avatar
mrfikser
when you pull the petcock you will see a screen on it..thats the filter
Old Apr 24, 2012 | 05:47 PM
Sportrider79's Avatar
Sportrider79
Most would disagree but I took mine off and put a clear inline filter on instead, partly because if I ever need to take it off I have to remove my tank becaue of clearance, I did a rinse out of the tank before I reassembled it
Old Apr 24, 2012 | 10:47 PM
Vdoubleyou's Avatar
Vdoubleyou
spoke to service at HD dealer abou
Old Apr 24, 2012 | 11:04 PM
Vdoubleyou's Avatar
Vdoubleyou
About setup and jet. Only the head guy knew enough about the carbs and he was in a build they took my name and #(I thought blowoff) he called me back about an hour later. We taled he listened, I listened he said the jetting is fairly common even on 883 he suggested the diaphram may be worn or damaged so within a few day I will check the seal on intake the filter in petcock change fuel and try again before I buy the diapham
Thanx to HD service for their fast responce
Thanx to the HDforum
Thanx to the people that care to spend the time to help
Old Jul 15, 2012 | 03:01 PM
Vdoubleyou's Avatar
Vdoubleyou
Found the needle jet was outta place thanx 4 help hd forum
T-sizzle
Nov 15, 2012 04:44 PM
leehd883
Jul 17, 2008 02:41 PM
brainfrz
Exhaust System Topics
May 16, 2008 05:17 PM
Hossman
Apr 7, 2006 05:20 PM
harleybiker
Sep 5, 2005 01:54 PM
