Is a fuel pak really required?
Anyways now that ive put 700+ miles on it i figured id install my v&h short shots and my joker machine air cleaner. It runs MUCH better and smoother but my co worker was saying I need a download for my ECU or it would void my warranty?
Iv heard i NEED a tune but ive also heard the stock ECU can handle the changes. For now im pretty happy with the way it runs is it really nessesary?
BTW its a 2012 if it makes any difference.
My best friend is a parts guy for HD, and I admit at first I was skeptical about the fuelpak when I bought my pipes, thinking it was a sales pitch but believe me it makes a huge difference, especially with a heavy breather. In regards to the warranty it's iffy. HD has to prove the aftermarket add on was the cause of an issue to void the warranty.
Now, do you have to have it? No, and it's highly unlikely it will cause any problems. If you want to MAXIMIZE your add on performance, get it. But definitely not required.
Btw mine is a 2012 as well.
Some say it needs a tune out of the box. Some say you can get away with pipes but NOT an AC. IDK. I know I couldn't get away with both on my 2011 because the AFR reading was way off. Your ECM can compensate for a bit but I am not sure how much. If you really want to know like I did years ago, I tapped into the O2 sensor wire on the sensor side of the plug. That way, if there is an issue, the sensor is easier to replace than the harness.
Just because I took you to court and got a judgment against you doesn't mean I will collect. In my old job, we had thousands of dollars of judgment but couldn't collect. Similarly, you can fight it and win but what is your time worth?
http://www.dummies.com/how-to/conten...ty-intact.html
