starter bench test?
Old May 3, 2012 | 09:22 PM
freewill's Avatar
freewill
Default starter bench test?
How do you bench test a 1987 Sportster starter motor?
I followed the manual instructions to test the solenoid - which works - but what about the starter - the only manual instructions are to take it apart.
Surely, it can be bench tested intact?
Old May 3, 2012 | 09:27 PM
Gpsjr10's Avatar
Gpsjr10
It is no different than testing a car starter. If you take it to any auto parts store, they should be able to hook it up to their machine. Although it won't be a load test and they probably won't have the specs for it, you can still see if it runs.
Old May 4, 2012 | 02:58 AM
freewill's Avatar
freewill
Thanks, I thought so. I am in Korea - "auto parts store"...explain what I want...have someone just do it...not going to happen.
I've seen bench tests for car starters, but the terminals are different. Mine has a ground, a positive from the relay, and a "field wire" from the solenoid to the starter...what can I do with those, apart from the solenoid test?
Throttle1971
Engine Mechanical Topics
21
Sep 1, 2024 12:21 PM
Harley1340vt
Jul 4, 2009 01:16 PM
dirty78ironhead
Ironhead
27
Nov 12, 2008 11:01 AM
Chris76
May 14, 2008 09:01 PM
kad640
Aug 22, 2007 04:27 AM
