More Speedo Problems
Old May 9, 2012 | 05:50 PM
06Sporty75's Avatar
06Sporty75
Default More Speedo Problems
I here the speedos are pretty bad on sportster, my 2006 1200c is stored outside, I understand many times problems are caused by wet/rusted fuses, over the past few days I have noticed my sercurity light has been staying on a few seconds after I start the motor, it worked fine this morning but this afternoon my speedo was dead and the security light was on when I started the motor and didn't start working until about 15 miles later. It's raining right now so i cant clean the fuses. But is that the most likely problem? I tried a search but it is absolutely not working, must be a software bug. Motor ran fine otherwise.
Old May 19, 2012 | 09:47 PM
06Sporty75's Avatar
06Sporty75
I cleaned my fuses but I'm still having occasional problems, today the speedo locked up at 30 mph and wouldn't turn off even with the ignition key in the off posistion, I had to restart the motor & turn it off again to get the speedo to reset and turn off. it locked up again later at 70 mph but started workign again in a few seconds. The needle will lock up on a random speed and I will also have the security light and check engine light come on and the odometer will go half blank and be unreadable.
I assume the speedo is the problem, atleast I hope it's not something more serious,
If one day the sppedo completely dies or gets really bad, should I try to get another Harley unit or should I just get the Dakota Digital. These HD units apparently have some kind of design flaw, if I were to buy a new one from a dealer, would it stop working after 6,000 miles too?
I installed one of these 3 months ago, but I dont think it would interfere with the speedo in anyway.,although maybe one of th wires on this gauger is touching the housing, That's something I should check.
, although I only having problems about once a week now so it must be something electrical inside the speedo unit.
http://www.ebay.com/itm/Harley-David...sories&vxp=mtr
Old May 20, 2012 | 09:50 AM
06Sporty75's Avatar
06Sporty75
I searched some old posts, read that it could be the Vehcile Speed Sensor, I took it out and it looked perfect, I dont think it would be causing the odometer display to go half out, so I'm still thinking my problem is with the Speedo.
Question: If I buy a used Harley unit say with 15,000 miles, will my ECM automatically update the correct mileage on the replacement Speedometer to show the correct mileage of 6,000?
Old May 20, 2012 | 09:56 AM
cHarley's Avatar
cHarley
No, the mileage info is actually stored in the speedo.
Old May 20, 2012 | 10:44 AM
Phantom6722's Avatar
Phantom6722
06sporty75, The speedo on my Heritage did the same thing over a long period of time, I think it is in the electronics (reset pulse for the speedo); I change out to a Dakota speedo with all the bells and whistles. If ya gonna upgrade, upgrade big. The new speedo works really well, although my bikes a 96 I did use all of the Dakota features.
Cheers
Skip
Old May 20, 2012 | 10:51 AM
Phantom6722
06sport75, that should read "although my bikes a 96 I didn't use all of the Dakota features".
ednigma
Sep 6, 2024 09:09 AM
eazyrider
Sep 1, 2008 09:26 PM
rwalters
Oct 14, 2007 05:25 PM
saltlick
May 16, 2007 10:08 PM
websterdan
Jan 8, 2007 03:13 AM
