here are some pics while i was putting on my drag bars, and after i painted the bike green, you can't see them real good on the second picture but you get the idea.
looks good. I 'm going to my dealer on monday and pick some up ... do I need different lines?...were they hard to install?...i have an 05 1200 custom!!!
no you shouldn't need lines unless your's are to long, judging from your pic. and they're so easy to install. just losen at the mounts, then take off the clutch/left switch housing, then take the mounts off and loosen the right switch housing/throttle, slide the bar from your throttle/right switch housing and you just removed your bars. installation is reverse of removal. hope this helps
well my T.S. barely touched with 32 inch pullback bars and a 4 inch riser with a 3.3 gallon tank (its not as wide, but its taller). so i think you might be ok with a wider pullbackbar. or a straight bar. "might". don't beat me up if i'm wrong.
