Front Mounted Controls (DIY)
Old Jan 6, 2007 | 10:38 PM
spottedfool's Avatar
spottedfool
Default Front Mounted Controls (DIY)
I have an 06 1200L and for christmas was given the front mounted control kit. I have everything finished except the brake connector because I am finding it impossible to remove the original brake line because the bolt is so hard to move, it wont even budge. Has anyone done this and know a trick or should I see if the dealership could pop this last part for me. One thing that makes it difficult are the pipes..right in the way.
thanks
Old Jan 6, 2007 | 10:46 PM
anubisss's Avatar
anubisss
Default RE: Front Mounted Controls (DIY)
Put a little heat on it with a torch...That should help...Something I have learned here as well.
Old Jan 6, 2007 | 10:47 PM
128auto's Avatar
128auto
Do you mean brake pedal push rod, you have to move the exhaust a bit to get that bolt off, it is very tight. All you have to do is take the exhaust mounting bolts off and you will be able to move the muffler a bit to get access.
Old Jan 7, 2007 | 12:42 AM
spottedfool
Yea I loosened the pipes and can get to it but all I am using is a torque wrench..looks like an allen wrench so its tiny and I have no leverage. Will keep trying..need it for work on monday
Old Jan 7, 2007 | 01:50 AM
DieHard's Avatar
DieHard
please if you are using a torque wrench to break bolts loose please stop using it that way you need a breaker bar. there cheap and do the job well.
and yes use a little heat, it will loosen up the loc tite that they use to put it together.
Old Jan 8, 2007 | 09:07 PM
spottedfool
Well I was able to get everything done. then ran it to the dealer for the 5k check up and they checked and tightened everything for me I must say riding with front controls is much for relaxing and to me a better ride...thanks all
Old Jan 8, 2007 | 09:24 PM
Wolhar's Avatar
Wolhar
ORIGINAL: DieHard
I believe he ment Torx
felix27
Jun 20, 2017 08:30 AM
scrams26
Feb 26, 2017 04:13 PM
Oddman
Oct 28, 2016 11:40 PM
hscic
Oct 7, 2015 02:00 AM
veniculum
Jan 12, 2007 10:12 PM
