Need Help Diagnosing
Old Jun 11, 2012 | 09:06 AM
Raider Dana's Avatar
Raider Dana
Default Need Help Diagnosing
Have 1999 1200S. Been running really bad. (Backfiring while riding, low power etc.) I checked the air filter, replaced the four spark plugs and put my exhaust gaskets in. And still runs crappy. Neighbor came by and said, Feel your front cylinder". It was cold. What should I check next? Ignition coil, plug cables? (Weird thing also: when i hit the choke, the other cylinder would kick on)
Thanks
Old Jun 11, 2012 | 10:23 AM
cHarley's Avatar
cHarley
Did this start happening while the bike was actively being used, or had the bike been in storage or sitting unused for some time?
Old Jun 11, 2012 | 01:48 PM
Raider Dana
cHarley - Actively used. My bike does not sit alot at all.
NHRS - I will check that out.
I appreciate both of your time.
Old Jun 11, 2012 | 02:38 PM
cHarley's Avatar
cHarley
A bad intake manifold gasket at the front cylinder is also a possibility.
Old Jun 11, 2012 | 04:04 PM
Zimbob's Avatar
Zimbob
How old are the wires? Give the coil a check also.
Old Jun 11, 2012 | 05:39 PM
wtb3886's Avatar
wtb3886
Greetings (Neighbor) Raider Dana
What pipes are you using?
Do you use a power commander?
Old Jun 12, 2012 | 06:52 AM
Raider Dana
Hi Neighbor,
I am using wrapped 1 3/4' Drag pipes.
They have been on since March.
I thought Power Commanders were for fuel injected bikes. I have a carb.
I appreciate your time sir, as well as your service.
Old Jun 12, 2012 | 07:03 AM
xFreebirdx's Avatar
xFreebirdx
+1 - My thoughts also.....
Old Jun 12, 2012 | 08:36 AM
AlexWS's Avatar
AlexWS
Air, fuel and spark. I'd start checking spark, it's the easiest. Pop off the plug boot, stick the tip of a screwdriver in(plastic handle) and hold the shaft of the screw driver so it's just hovering above the jug, close enough to arc. Now it would be good if you had a friend to help you with cranking it, if the coil/wire are good you should be able to see it sparking on the engine.
EDIT: just saw the comment about firing with the choke, most likely eliminates spark but still wouldn't hurt to check.
A trick we would always do was spray some starting fluid (or anything flammable) around the suspected leak area. If you get a sudden rise in RPM it's because it sucked it in and ignited it. Be careful that the engine isn't too hot.
Old Jun 12, 2012 | 09:30 AM
Raider Dana
cHarley is the winner, it was the intake manifold gasket, and the bike is back to its full power.
I appreciate all the advice given by all of you.
