problems starting
Old Jun 12, 2012 | 09:46 AM
kickboxinghelen's Avatar
kickboxinghelen
Stage II
Default problems starting
I'm having a few problems with my 2007 xlr 883 sportster
sometimes the alarm won't deactivate so I have been entering the pin number to start it. However, just lately I can't do this, I turn the key and press both indicator buttons immediately but the row of zero's doesn't appear in the odometer. I've been getting round this by turning it off and on several times and eventually it comes to life and you can start it. Quite often when I turn it on, nothing at all happens, there are no lights in the display and the computer doesn't come to life, if I wiggle the key around that sometimes works, or sometimes I wiggle the fuses and that brings it back to life. I appreciate it must be some kind of electrical fault but any ideas where to start?
Old Jun 12, 2012 | 10:11 AM
cHarley's Avatar
cHarley
07 Sporties are notorious for water intrusion problems in the fuse block/relay area. This leads to corrosion on the contacts of the fuses and relays.
If you don't have some, pick up a tube of dielectric grease from your local auto parts store. Remove all fuses and relays, clean the contacts on all of them and then coat the contacts with the grease and reinstall.
Old Jun 12, 2012 | 10:18 AM
kickboxinghelen
Stage II
great, I'll try that later, I wondered if it was water related as it always seems to play up the most when its been raining for days
jokerjoed
Sep 8, 2014 12:19 PM
gallensworth
Aug 7, 2011 03:58 PM
Boner1200N
Mar 31, 2011 09:43 PM
bayou sportster
Mar 21, 2011 05:44 PM
Galderdrone
Jan 17, 2011 12:27 AM
