Fat front tire question.
Old Jun 24, 2012 | 10:37 PM
Sitting Bull's Avatar
Sitting Bull
6th Gear
Default Fat front tire question.
As you probably figured out I am very new to HD's. I would like to know how old of a sportster can I go in order to get the fat tire in the front like the 2012 1200 custom as opposed to the narrower tire?
Old Jun 24, 2012 | 11:44 PM
Captain Smooth's Avatar
Captain Smooth
The newer sportsters like the custom and the 48 have wide glide front ends, I think this started 2010 but I am probably wrong on that. I am sure someone will chirp in that knows better.
Old Jun 25, 2012 | 06:04 AM
JonFMJ's Avatar
JonFMJ
Pretty sure cpt smooth is right. It would be a matter of swapping out the triple trees and forks. Not to mention everything that goes along with it. If your wallets big enough then go for it. But, I've never done one so I have no idea what it does all entail.
Old Jun 25, 2012 | 06:55 AM
modular's Avatar
modular
Might want to take a look at this thread doing just what you are asking about.
https://www.hdforums.com/forum/sport...l-on-07-a.html
Old Jun 25, 2012 | 08:00 AM
Sitting Bull
6th Gear
Thanks for your replies
I thought I had seen some older bikes with a fat tire, but I am probably wrong , it was probably the angle of the picture.
Old Jun 25, 2012 | 08:02 AM
Sport1200N's Avatar
Sport1200N
the nightster has a tire that's wider than the older customs but not as wide as the 48
Old Jun 25, 2012 | 08:06 AM
rickss69's Avatar
rickss69
The newer bikes are using a H-D hybrid mid-glide front-end, not a wide-glide. Far and away more expensive to duplicate H-D's experiment, you will be better served and have more options as well as more money left in your pocket going with an aftermarket wide-glide conversion kit. The bike in my sig uses a Vulcan WG kit with 150/80-16 tires front and rear.
Old Jun 25, 2012 | 01:55 PM
Nubz's Avatar
Nubz
You more likely than not saw exactly what you thought you saw
People have been changing front ends forever
Old Jun 26, 2012 | 06:40 AM
grbrown's Avatar
grbrown
You may be able to fit a fat tyre in older bikes, but this is not a bolt-in job you can do with your eyes closed! People are installing wide tyres and wider rim wheels all the time, but this is what 'customs' are all about. If you have the right skills or are up for a challenge, then do it. I am busy squeezing a Deuce rear wheel into my 1990 Glide at present, so am just a little ahead of you!
heathdeloach
Jul 17, 2017 10:25 PM
brock29609
Oct 13, 2014 11:14 AM
karaokeman
Feb 10, 2011 05:20 PM
scooterbooter
Jan 28, 2006 09:30 AM
Talon07
Nov 6, 2004 01:37 AM
