High beam problems
Old Jun 25, 2012 | 08:17 PM
Matt125's Avatar
Matt125
Stage I
Default High beam problems
I have a 2005 Sportster 1200 and every time i put the high beam on it blows the fuse. I know the easiest way to fix it is to not put the high beam on, which i have been doing for about a month now but i was wondering if anyone else has had this problem and if anyone has any advise on a better way to fix it than to not use it fix.
Thanks, Matt
Old Jun 25, 2012 | 08:24 PM
Wanna Ride's Avatar
Wanna Ride
Only one thing will do that... a direct short to ground.
Check your high beam power wire... I'll guarantee it's shorted somewhere. If you know how to use a multimeter, you can ohm this out and isolate the problem area of wire.
Old Jun 26, 2012 | 05:22 AM
DOMAPOI's Avatar
DOMAPOI
I totally agree.
Old Jun 26, 2012 | 07:51 AM
1984_FXRT's Avatar
1984_FXRT
Pull the light outta the headlight bucket, and look very carefully for wires that are chafed through the insulation. Dollars to donuts - this is what's causing your problem.
Old Jun 26, 2012 | 07:54 AM
Gpsjr10's Avatar
Gpsjr10
Also check inside the switch housing and where the wires come out through the dimpled area on the bar. If the switch housing got rotated, it could be pinching the wire.
Old Jun 26, 2012 | 08:22 AM
JonFMJ's Avatar
JonFMJ
What they said.
Old Jun 26, 2012 | 09:57 AM
cHarley's Avatar
cHarley
Assuming that you're not the original owner, make sure that the stock 60/55 watt bulb wasn't replace with a higher (100) watt bulb and that the bulb socket isn't melted. The higher wattage bulb will literally melt bulb socket.
Old Jun 26, 2012 | 06:55 PM
HarleyScuba's Avatar
HarleyScuba
For sure:
Old Jun 26, 2012 | 07:17 PM
Booey424's Avatar
Booey424
Originally Posted by HarleyScuba
For sure:
I also had this happen. It took 2 years but it finally melted just like that pic
89FLHTC
Electrical/Lighting/Alarm
Jan 10, 2016 11:23 AM
Dan33klein
May 28, 2014 08:52 PM
Retrop
May 20, 2013 10:55 AM
BrassHOLE
Jul 19, 2011 08:48 AM
Chazmanian
Jul 10, 2009 06:15 PM
