Electrical query....
Old Jul 9, 2009 | 08:11 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Default Electrical query....
I do most if not all of my own wrenching on everything short of the motor...
But I'm a wiring spazwad and if it isnt something thats already there I'm easily stumped.
This sounds silly but...
I'm replacing my exsisting headlight with another aftermarket unit.
My exsisting headlight is a 3 wire setup which must have something to do with the high and lo beam I'm assuming?
My new headlight only has two wires. Is this now a no high beam headlamp and if so do I simply not attach one of the wires?
I figgered to check the exsisting wires and see which is powered and when according to the postion of the hi-lo switch but now I'm unsure and would like to wire the light where its not on 24-7?
Is that 3rd wire for the hi-lo is that for the always on daytime running light deal?
Man I'm an idiot with wiring!!
Old Jul 9, 2009 | 08:20 PM
agapsdiver's Avatar
agapsdiver
It would be illegal for you not to have a headlight on 24/7.
Old Jul 9, 2009 | 08:26 PM
Lucky 13's Avatar
Lucky 13
You have to look at the bulb to tell if its duel (low / High) beam. If it has 2 elements its low and high. Your stock light has 3 wires low, high and a ground wire. Its my guess that your new light has 2 wires for low and high beam and probably grounds through the fixture. If you have a simple ohm meter you could confirm this. Really hard to say without seeing the light.
If I'm right it would be the ground wire to eliminate.
Old Jul 9, 2009 | 08:27 PM
Blk and Chrome's Avatar
Blk and Chrome
one wire is for low beam, one for high beam, one is a ground. You should be able to use the two hot wires on the one leg so if you hit the swtich by mistake the light wont shut off
Old Jul 9, 2009 | 08:29 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Really? I have seen lots of custom bikes running around without daytime running lights and my 2008 KTM which is technically a dirt bike but has the euro lighting kit isnt 24/7 lit and I have never been pulled over or even given a second look....Cept fer' the time I wheelied through an intersection on the right side during rush hour!!
Needless to say what the deal on the 2 wire Vs' 3 wire setup. Is the 2 wire not gonna have hi-lo or daytime runners?
Its not a big deal as i would probably run the headlight during the day anyway I just dont really get wiring and dunno what I'm looking at losing?
Old Jul 9, 2009 | 08:34 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
So I dont need the ground wire then? The headlight just has yellow and red lines. No ground. I have a multimeter although the ground on the exsisting light is black. I then have white and yellow.
It is in fact a High Low setup with the multiple piece element.
So I'll just run the yellow to the yellow and the white to the red and eliminate the black...
Old Jul 9, 2009 | 08:35 PM
phantom rider's Avatar
phantom rider
The 3 wires on your bike are Hi, Low, Ground. The new headlight probably has 2 wires because it is grounded through its connection to the frame. Not sure which headlight you bought, but here is a link to a thread from a while back...
https://www.hdforums.com/forum/softa...ring-tips.html
Old Jul 9, 2009 | 08:39 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
You rock. I would have wired it bassackwards were it not for your thread!!
Thanks.
Red to yellow.
Yellow to white.
Harrumph!
I have the same light as you cept fer it has that little spiky tip.
Old Jul 9, 2009 | 08:43 PM
Lucky 13's Avatar
Lucky 13
Yes, yellow is high beam on a Harley and probably on your new light,The black is ground. You could either tape off the black and let the new light get its ground through the mounting bolt or if that ground is questionable, crimp a eyelet to the end of the wire and slip it over the mounting bolt before you tighten the nut down.
Old Jul 9, 2009 | 09:02 PM
spooner's Avatar
spooner
agapsdiver is correct. Somewhere around 1975, it became mandantory for all motorcycles manufactured after that date to have daytime running lights.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
