Max two up weight 1200C
Old Jul 7, 2012 | 11:41 AM
Falcon195's Avatar
Falcon195
Default Max two up weight 1200C
So what would you guys say is the max total two up weight that a 2011 1200 C can handle without any issues?
I am 220 and my wife 130 and when I ride two up I set the shock preload to the max setting of 5 and the bike seems to have enough power and handles the weight OK but I was wondering what the real max load on this bike is.
Old Jul 7, 2012 | 11:55 AM
Scuba10jdl's Avatar
Scuba10jdl
Take the GVWR of your bike (can't find it online, should be labeled on the frame or in your manual) and subtract the weight of the bike.
That's the maximum load allowable. Then you have to pay attention to front and rear distribution, tire load, etc.
A safe bet is max is probably right around 350 - 400 lbs total, as that is about what it is for my bike. So you're pretty close there.
Old Jul 7, 2012 | 12:31 PM
baka1969's Avatar
baka1969
I'm also 220 and my passenger is just shy of yours and on my 883 it does pretty well. The only exception is on hills where it seems to work hard. I agree that 350-400lbs is probably what it's rated for with the stock shocks. Upgrade the shocks/springs to something like the Progressive HD 412 and I bet it would be rated for an additional 40-60lbs.
Old Jul 7, 2012 | 12:57 PM
wanabe's Avatar
wanabe
and if you are concerned, its not hard to increase our HP on this bike... (pipes and sucker- with tuner)
as to 2 up issues, i think that the stock seat and shocks need to go-
my fav for 2 up is the wide mustang combined with 1" longer shocks using works performance (they custom build them for your weight)- i also changed the front shock oil and used a weight that is between stock and screaming eagle.
my 2 up seat and shocks:
Old Jul 7, 2012 | 01:01 PM
Scuba10jdl's Avatar
Scuba10jdl
It's not the shocks that are rated really, but the bike itself. The axles, frame, swingarm, etc. can't take the stress the weight adds.
I'm sure it is over-engineered, but exceeding the GVWR even with shocks that can handle it is adding undo stress to the vehicle. In time something will break.
Old Jul 7, 2012 | 02:17 PM
Falcon195's Avatar
Falcon195
The GVWR of my bike is 1000 lbs the running weight of the bike is 582 lbs which leaves 418 lbs of passenger and cargo weight.
Thanks for your help.
Old Jul 7, 2012 | 05:00 PM
buckeyesound's Avatar
buckeyesound
my manual list 1000 lbs gross for all 2010 Sportsters.
deebats
Dec 31, 2019 08:17 AM
Falconetti
Nov 16, 2016 10:23 AM
tatrhed
Jul 6, 2015 10:10 AM
ColoHarleyGirl
Dec 20, 2011 02:05 AM
mmullins2000
Aug 14, 2011 11:40 PM
