Ignition
Old Jan 18, 2007 | 01:16 AM
Wolhar's Avatar
Wolhar
Default RE: Ignition
I'm told by a HD Tec, that the SE Ignition Module, listed for $119.00 is useless and a waste of money, the only perfomance gain it affords is rev limiter is increased. Save yer money.
Old Jan 18, 2007 | 02:48 AM
bigtop1's Avatar
bigtop1
Can we discuss this for a minute. If an ignition module will allow you to get a few more revs out of a gear(500 more with the SE over stock I believe?) then aren't you getting more from the engine power wise? It's just like not having full throttle capability on the carb. Once set to go the limit, would you be able to get an additional horse or 2? Realizing that going the limit all the time causes more stress on the engine of course.
[/align]
Old Jan 18, 2007 | 09:19 AM
slammedsporty04's Avatar
slammedsporty04
Just because you can rev the motor to a higher RPM does not mean you are going to gain more hp. it is all about how you have your motor set up. if you are running cams that have a power band in the high rpm's then yes you could get a few more hp's out of it. but it you are going to spend the money to redo your motor why wouldn't you spend the extra few dollars and get a good ignition with good tuning capabilities. The SE unit is use, basically your paying 120 dollars to raise you rev limiter.
Old Jan 18, 2007 | 09:40 AM
jwb47's Avatar
jwb47
I can see where a tunable ignition would benefit in a situation like xl ocd stated, I thik the gains are more in the lines of a more effecient motor than instant horsepower.
Old Jan 18, 2007 | 11:00 AM
ronn39's Avatar
ronn39
Changing the ignition module isn't going to give you a hotter spark. Changing the coil will. But it's my opinion that the stock coil is hot enough for all but the most severe engine mods.
NCCopBikeRider
27
Jun 8, 2024 01:18 PM
big98
Apr 3, 2020 02:44 PM
steelerdude1
Dec 24, 2018 07:34 PM
tacarpe
Feb 18, 2013 08:46 AM
cootertwo
Mar 26, 2006 09:03 PM
