Kuryakyn Hypercharger.
Old Jul 28, 2012 | 11:36 PM
JeffJA's Avatar
JeffJA
Default Kuryakyn Hypercharger.
I have a 2009 1200c, so far i have V&H straight shot slip on's and a V&H fuelpak, i'd like to ad a Kuryakyn Hypercharger, is this a direct bolt on? everything included in the kit? and sponsors on here carry them?...any info on this would GREAT!
thanks!
Old Jul 29, 2012 | 04:01 AM
xFreebirdx's Avatar
xFreebirdx
Originally Posted by JeffJA
I have a 2009 1200c, so far i have V&H straight shot slip on's and a V&H fuelpak, i'd like to ad a Kuryakyn Hypercharger, is this a direct bolt on? everything included in the kit? and sponsors on here carry them?...any info on this would GREAT!thanks!
The Hypercharger is crap and I wouldn't waste the money on it..........
Old Jul 29, 2012 | 08:33 AM
baka1969's Avatar
baka1969
I'm not a fan but it's a personal choice. It should come with everything you need. I'm not sure what map you'll need to load but maybe a call to Kury would help?
Old Jul 29, 2012 | 08:35 AM
Iceman24's Avatar
Iceman24
^^Agree^^
All "looks" and poor performance...do a search & you'll see the issue(s). Main problem is poor air circ. in intake cowling...created little "vortex" affects which cause issues. Better off w/HD's heavy breather...JMO.
Old Jul 29, 2012 | 08:39 AM
TORQUEY's Avatar
TORQUEY
Do some searching here for hypercharger. Comments seem to be about 80% negative. There are so many other, nicer choices.
However, to each his own...
Old Jul 29, 2012 | 11:02 AM
JeffJA's Avatar
JeffJA
well...that settles that, i'll pass on it...what do you guys recommend?..id like to stay under $300, thanks for the info so far!
Old Jul 29, 2012 | 11:12 AM
IRON1250's Avatar
IRON1250
You made the right choice^^^^^ From what i have heard they are junk!
Old Jul 29, 2012 | 11:20 AM
useR 564357348's Avatar
useR 564357348
I don't understand all the negitive PR. I ran one for years and never had a problem and it performed well. And with the right pipe combo it produces a sound second to none.
Old Jul 29, 2012 | 11:50 AM
cHarley's Avatar
cHarley
Not only has the Hypercharger been repeatedly proven on a dyno to be a poor performer, it performs even worse on the the road at higher speeds.
While the Hypercharger looks like a "ram" air intake, the hole located on the backside, rear-end of the can, allows air flowing into the front of the can to flow past the carb/TB intake and out of the hole. This flow-by creates a negative pressure across the carb/TB opening, actually reducing intake air to the motor.
Old Jul 29, 2012 | 12:01 PM
IRON1250's Avatar
IRON1250
cHarley thats the only way to know . Dyno. they do look neat though. i'm sure anyone saying they perform better than a normal high flow air cleaner hasn't had it on a dyno before and after install. I'm sure they work ok. I wouldn't want one though.
