Rev limiter?
Old Jul 31, 2012 | 09:21 PM
dvanhorn's Avatar
dvanhorn
Default Rev limiter?
I just got a 00 1200s and I have a rev limiter question. Can someone tell me what the factory limiter is set at? Mine acts like it hits around 55 - 6k does that sound right or am is it to low? Thanks, Dave
Old Aug 1, 2012 | 12:34 AM
rickss69's Avatar
rickss69
If I recall my '07 Roadster was around 5600rpm.
Old Aug 1, 2012 | 12:46 AM
Scuba10jdl's Avatar
Scuba10jdl
Should be 6200 rpm. They dropped it in '04 to 6000 rpm and further on...
Old Aug 1, 2012 | 07:54 AM
run1fsr's Avatar
run1fsr
Hey Scuba - Do you know what year they began installing limiters on Sportsters?
Old Aug 1, 2012 | 08:35 AM
1984_FXRT's Avatar
1984_FXRT
Not scuba - but, rev limits are a function of the ignition module.
They began when HD went to an electronic ignition - I don't know exactly when that was, but, would hazard a guess that it was in the later model FEs.
Old Aug 1, 2012 | 09:58 AM
marine_hm@hotmail.com's Avatar
I read the other day that reaching the "rev limiter" causes bad things. What happens? I can understand not burning the fuel, maybe fouled plugs? What else?
Old Aug 1, 2012 | 10:05 AM
cHarley's Avatar
cHarley
Rev limiters were introduced on Sportsters with the release of the XLH-1200, which I think, was 1991(?).
Old Aug 1, 2012 | 10:07 AM
Scuba10jdl's Avatar
Scuba10jdl
It doesn't cause bad things unless the limiter is set too high. The point of the rev limiter is to prevent the motor from running too fast for the valvetrain and pistons that are in it.
Our bikes don't have the valvetrain or light pistons to sustain RPMs over about 6000 or so (give or take a little) without getting piston slap, valve float, and so on.
Old Aug 1, 2012 | 10:14 AM
cHarley's Avatar
cHarley
Hitting the rev limiter simply cuts off the ignition (spark), but as soon as the RPMs drop into the safe range as the result of ignition loss, the ignition starts firing again. This fast on/off switching of the ignition makes the motor feel like it has a bad, rapid, stutter until you let off the throttle. Unless someone's an idiot and continues to keep it in the rev limiter "zone", occasionally hitting the limiter doesn't really hurt anything.
Old Aug 1, 2012 | 10:21 AM
I twisted my throttle the other day just to see what I had. I've taken off the tach due to the cable passing over the exhaust "cross-tube?" I hit 80+mph and it started surging/backing off. I hope I described that correctly. I'm only assuming that was my rev point. I backed off and she runs fine. I may have to re-install the tach and do it again just to see where it's set. I do know that the Crane Hi4 is factory set. I've not ****ed with it. So, maybe ya'll would know what it's set at? Thanks to ALL that have set me straight since I got my bike up and running.
Thanks cHarley! I didn't refresh my page until after I wrote this comment. Yours poped up after I wrote this. Then re-read Scuba's post. So mine is relatively around 6K rpm?
Last edited by marine_hm@hotmail.com; Aug 1, 2012 at 10:34 AM. Reason: Thanks cHarley, Scuba
