Need help with a wire
Old Aug 5, 2012 | 05:18 AM
cavalier2000's Avatar
cavalier2000
Default Need help with a wire
Ok before anyone says it YES I HAVE A MANUAL.
I am in the process of putting my bike back together. (did a complete strip)
But I have a ground wire I have no idea where it goes. it's on the right side... on the rear motor mount bolts. (upper bolt) about the only thing I can find about it is that it routes down between the swing arm and the frame... but to be honest I could be wrong.
Does that make sense? I could snap a picture of it if need be,
Old Aug 5, 2012 | 08:57 AM
nc883's Avatar
nc883
What gauge is it? I can look on my '02 for you. And length?
Old Aug 5, 2012 | 02:08 PM
run1fsr's Avatar
run1fsr
Wire or a cable? If you mean a cable it is likely the negitive from your battery
... confirm using your manual.
Old Aug 5, 2012 | 04:34 PM
cavalier2000
Wire, the battery cable is really noticible. Lemme snap a picture
Old Aug 5, 2012 | 04:48 PM
cavalier2000
Here is it mounted to the frame
and here is the end of it
it's small and kinda short, if need be i can pull it off though at first I thought it went to the rear brake sensor but the main harness already has two wires for it.
khui
Apr 8, 2013 12:36 PM
Sparkplug666
Dec 8, 2012 01:38 PM
Travelight
Jul 10, 2010 12:26 PM
SgtMic
Jun 29, 2009 12:12 PM
SmokerMI
Oct 9, 2008 08:47 AM
