do you need to relocate your horn? i read somewhere on there site you have to?
do you have to modify any wires? especially when relocating the iginition key
The horn will be fine. The most modification I had to do for the ignition relocation was cutting a slit in the mesh wire wrap in order to pull out the ignition wires. I have the flex-6 mod though so it moves it further back. If you put it between the jugs there may be enough wire exposed.
