Front Turn Signal Relocation
Old Aug 26, 2012 | 05:43 PM
user 084208424's Avatar
user 084208424
Default Front Turn Signal Relocation
I was feeling a bit crafty today and decided to do a cheap and easy relocation of my front turn signals with some parts I had laying around the garage. I had a couple of conduit hanger clamps and had seen somewhere else that they were used for the same purpose, so I broke out the rattle can, gave them a shot and bolted them up. Here's the results.
Old Aug 26, 2012 | 05:54 PM
Davemac122383's Avatar
Davemac122383
Cool idea and nice work. Any close ups? Can you post a pic of the clamps you used? I'm pretty sure I know what you used. I'd like to do this and not have any problems, since you already did the hard part of figuring it out. Thanks
Old Aug 26, 2012 | 08:32 PM
user 084208424
Here is a link to the part that I used:
http://www.homedepot.com/h_d1/N-5yc1...1#.UDrMyEVmycc
I've worked with conduit in the past and saw them sitting around and figured I'd try it out. I had to file the hole on the flat part a little larger to fit the 5/16 bolt to attach the turn signal. I applied a little Loc-Tite, threaded a nut up against the inside to keep it solid on the mount, and then twisted it into the light. I think the bolt was either 3/4" or 1" long. I didn't get a close up shot while I was working because I left a small blemish in the paint on the bracket that I need to touch up!
I can't take full credit because I did see a variation of this elsewhere but there wasn't a parts listing or walkthrough.
Old Aug 26, 2012 | 08:40 PM
Davemac122383
Thanks for the response back with all the info, def something I'll be doing soon.
Old Aug 26, 2012 | 11:10 PM
blindrocket's Avatar
blindrocket
Nice job.
I'm using leather black outs on my upper forks so this method wouldn't work for me.
I would like to do something similar to this (from another hdforum member) but I'm not going to spend that much coin:
http://www.ebay.com/itm/Harley-David...e2e7b8&vxp=mtr
Old Aug 27, 2012 | 01:06 AM
ahhwataday's Avatar
ahhwataday
aw hell yea, looks good man and thanks for the idea.
gearhead1937
Oct 31, 2013 12:12 PM
charle
Apr 26, 2013 09:10 PM
Aces and 8s
Mar 3, 2013 09:01 AM
Zeteo
Feb 19, 2013 04:31 PM
TangoDown
May 26, 2011 04:51 PM
