2000 Stock Sportster spits occasionally when revving cold or warm
Old Aug 27, 2012 | 02:40 PM
LouHarle's Avatar
LouHarle
5th Gear
Default 2000 Stock Sportster spits occasionally when revving cold or warm
Bike is completely stock, with 8000 miles on it, when revving it will every 10 or so times I rev. tried replacing the plugs (didn't use HD, used Champion) with no improvement. any thoughts?
Thanks!
Old Aug 27, 2012 | 02:46 PM
nc883's Avatar
nc883
Are you referring to a "carb fart"?
If so, try going thru the carb and cleaning it up. That age, that low mileage, sounds like it's sat alot. Otherwise, a more detailed explanation might be in order.
Old Aug 27, 2012 | 02:49 PM
LouHarle's Avatar
LouHarle
5th Gear
Default Carb Fart
yeah, you could probably call it that... :-)
would a carb cleaner be worth running through it?
Old Aug 27, 2012 | 05:04 PM
John Hyatt's Avatar
John Hyatt
Lou my man.
Let....It.....Warm...Up. Before you start reving it
As a 1200 2000 rider dimes to donuts that is your problem. If you can call it that.
JonMon
Old Aug 28, 2012 | 07:54 AM
LouHarle's Avatar
LouHarle
5th Gear
Howdy, bike, even warmed up will spit every 10th time or so revving.. seems generally to happen if I don't let it completely come down from a previous rev... thinking it probably is crap in the jets or something but wanted to query the masses to see if carb cleaner might help...
thanks!
Old Aug 28, 2012 | 10:32 AM
mikhailwatt's Avatar
mikhailwatt
2000 XL1200C w/ 8,000 miles..........
I'll get the "spitting" occasionally, usually when when the throttle is cracked halfway open. Seems to be related to cold mornings - warm afternoons, no problem. My assumption has been that the factory jetting is a bit on the lean side, and the heavier morning air leans it out even more. ???
JakePie
May 15, 2019 09:01 PM
cgoree
Dec 3, 2014 07:14 PM
Nibin
Jul 18, 2013 03:01 PM
khill8469
Aug 28, 2011 08:26 PM
tbow33
Oct 7, 2008 09:28 PM
